b20-vtec or ls-vtec with jrsc????
ok guys my goal is to have over 300whp which of this would be better and i want to use a JRSC also any recomendatios or anyother setup i dont really want a turbo and all of this is going into a CRX SI
THANKS GUYS FOR YOUR OPTIOS
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by curioso »</TD></TR><TR><TD CLASS="quote">ok guys my goal is to have over 300whp which of this would be better and i want to use a JRSC also any recomendatios or anyother setup i dont really want a turbo and all of this is going into a CRX SI
Either will work fine, but neither will make over 300whp. The blower doesn't flow enough. 290-300whp is the most you'll make and that is with an ideal intercooled setup.
The new EATON blowers will flow more so they'll allow you to go over 300whp. Unfortunately they aren't ready until fall 2007.
</TD></TR></TABLE>Either will work fine, but neither will make over 300whp. The blower doesn't flow enough. 290-300whp is the most you'll make and that is with an ideal intercooled setup.
I did it, and I was only using a dinky little B16
https://honda-tech.com/zerothread?id=1293497
Of course a few additional components and some fabrication were required...................
