WHAT IS WRONG WITH MY CIVIC?
99 HONDA CIVIC EX. DRIVE LIGHT IS FLASHING, CHECK ENGINE LIGHT IS ON. EMERGENCY BRAKE LIGHT ON SOMETIMES WHEN DRIVING. SHIFTS HARD. DOES NOT ACCELERATE IN DRIVE 4 ONLY 2 OR 3. NO SPEEDOMETER AND MILES ARE NOT MOVING. HAPPNEDED ALL OF A SUDDEN WHILE DRIVING, NO WARNING SIGNS THAT ANYTHING WAS PREVIOUSLY WRONG OR BREAKING. I HATE THIS CAR, AND IT WAS NOT THE VSS, I TRIED THAT FIRST. HELP ME!! I WAS JUST ABOUT READY TO TRADE IT IN TOO!!
my e-brake light went on when I had low brake fluid once but im not sure if thats the reason in this case... im not sure whats goin on with everything else though
your speedo, vss problem could be a fuse so make sure all fuses check out ok then you can go from there..
Your D light is flashing because your transmission is not operating correctly. The D light flashing because there is a DTC set..
Your Check Engine Light can also be related to this code, but it can also be a totally different code.
The brake light can be a number of things. Start off by checking your brake pads to see if they are low. If not, then it can be a leak somewhere in the system causing the float in the reservoir to drop to the bottom setting off the light. It can also be a faulty float, this is a known problem with hondas.
Good luck
Good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdeemseerx »</TD></TR><TR><TD CLASS="quote">your speedo, vss problem could be a fuse so make sure all fuses check out ok then you can go from there..
Good luck</TD></TR></TABLE>
Do what he said.
Do what he said.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdeemseerx »</TD></TR><TR><TD CLASS="quote">yes! finally someone who knows what their talking about.. real informative noob
Remember, we were all there once... give him some pointers
Rich
</TD></TR></TABLE>Remember, we were all there once... give him some pointers
Rich
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbospec03 »</TD></TR><TR><TD CLASS="quote">check all ur sensors</TD></TR></TABLE>
Yeah, all of em
I agree do what jdeemseerx said.
Yeah, all of em
your system is an obd2 go to autozone and ask to borow thee scanner, make sure ur car is in postion 2 when pulling the codes, check trans fluid level, brake fluid level, fuses, relays, and make sure all connections on the trans are hooked up,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jerseytune »</TD></TR><TR><TD CLASS="quote">99 HONDA CIVIC EX. DRIVE LIGHT IS FLASHING, CHECK ENGINE LIGHT IS ON. EMERGENCY BRAKE LIGHT ON SOMETIMES WHEN DRIVING. SHIFTS HARD. DOES NOT ACCELERATE IN DRIVE 4 ONLY 2 OR 3. NO SPEEDOMETER AND MILES ARE NOT MOVING. HAPPNEDED ALL OF A SUDDEN WHILE DRIVING, NO WARNING SIGNS THAT ANYTHING WAS PREVIOUSLY WRONG OR BREAKING. I HATE THIS CAR, AND IT WAS NOT THE VSS, I TRIED THAT FIRST. HELP ME!! I WAS JUST ABOUT READY TO TRADE IT IN TOO!!</TD></TR></TABLE>
and if you ever post something in all caps again, I will stab you in the eye!! JK, I wont, but seriously, dont tempt me.
Umm.. I'd check the code that the ECU is throwing.. If you dont know how do a search on "how to check engine code" or something..
And you might want to check your caps lock too.. I think it's broken..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spork motorsports »</TD></TR><TR><TD CLASS="quote">perosnally i dont give a damn if he types in caps or not
you may not care, but it is hard to read and painfully annoying to everyone else. ALL CAPS, talkn lik dis, and run on paragraphs are all horrible to read
</TD></TR></TABLE>you may not care, but it is hard to read and painfully annoying to everyone else. ALL CAPS, talkn lik dis, and run on paragraphs are all horrible to read
