Getting "Communication Error" with a scanner after swap...
Old Nov 6, 2006 | 10:45 AM
CivicSwapper's Avatar
Default Getting "Communication Error" with a scanner after swap...
Just swapped in an OBD2 b16 into my 96 hatch. The car is cranking but it wont start. We tried hooking my friends scanner up to the ecu to check the codes but its saying "Communication Error". Any ideas why?
Old Nov 6, 2006 | 10:55 AM
locash's Avatar
Default Re: Getting "Communication Error" with a scanner after swap... (CivicSwapper)
What ecu are you using?
Old Nov 6, 2006 | 10:56 AM
Default Re: Getting "Communication Error" with a scanner after swap... (locash)
P2T
Old Nov 6, 2006 | 02:08 PM
locash's Avatar
Are you using a 96-98 engine harness and an ECU adapter? If not, thats your problem, as the US P2T ecu only came in the 99-00 Civic Si and the ecu wiring is different between the 96-98 and the 99-00 cars.
k-oz
Engine Management and Tuning
Jul 17, 2011 10:42 PM
808kyle808
12
Mar 13, 2009 07:24 PM
fathergoose
Jan 5, 2006 04:19 PM
Nusport_racing
Apr 21, 2004 12:15 AM
RacerXI
Oct 21, 2002 11:17 AM
