GEARS KEEP LOCKING! PLEASE HELP
Old Nov 5, 2006 | 09:23 PM
jlh22179tx's Avatar
Default GEARS KEEP LOCKING! PLEASE HELP
i have a ek4 with a b18c-r and just lately when i try changing gears it keeps locking (in the middle of the gearbox) for a second then lets me in. i have to wait till the rpm drop when i clutch it to change gear. it kinda feels like when you are trying to put the car to first when rolling to a stop. if your going to fast it wont let you till u hit the right speed. anyone know what is happening?
Old Nov 6, 2006 | 06:31 AM
macfadyen's Avatar
Default Re: GEARS KEEP LOCKING! PLEASE HELP (jlh22179tx)
i had a problem like that but much worse and i took the tranny out and the clutch springs had blown out of the clutch so maybe id check that
i replaced the clutch and the problem was gone....
Old Nov 6, 2006 | 07:12 AM
pdiggitydogg's Avatar
it could be the springs, but im leaning more toward internals, like the synchros or forks.
When it does this, does it grind?
Old Nov 6, 2006 | 10:00 AM
jlh22179tx's Avatar
Default Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">it could be the springs, but im leaning more toward internals, like the synchros or forks.
When it does this, does it grind?</TD></TR></TABLE>
it does sometimes but a small grind. i would have to drive the car slow and change gears while the rpms are still low. if i change gear when the rpm is like past 3k it will lock till it drops.
i dont think its the clutch since the clutch still feels normal. still bites.
friend mention the throw out bearing cause its makes a spinning whining noise when i lift off the clutch before it bites.
Old Nov 9, 2006 | 08:59 PM
IndySporty's Avatar
yeah sounds like throwout bearing. I did a clutch job on my integra not long ago and it would go into any gear for like 5 monutes finally I got it into 5th then reverse then 4th then 3rd and so on and very hard to shift. And the whining noise. After I drive it a few miles it got better and eventeually went away, I was lucky in that my bearing aligned itself the rest of the way I must have not had it seated into the flywheel just perfectly.
lance_ecl
Aug 15, 2007 06:32 PM
integ R a
Dec 5, 2004 05:52 PM
ITR Buddy
Jun 13, 2004 03:45 PM
P73typeR
Feb 4, 2004 11:20 AM
esoterEK..
Oct 5, 2003 09:19 PM
