help with tranny problem!!
Old Feb 4, 2004 | 06:15 AM
P73typeR's Avatar
Default help with tranny problem!!
i started having problems with shifting gears friday night...it was really hard to drop the gears and even shift the gears...they were like real stiff and werent shifting smoothly...i started to think maybe my rear motor mount since it was gone and all but i got that fixed and it didnt help at all and then we flushed and put in tranny fluid....so now i have no clue what it could be? when im at a dead stop and start to release the clutch the car vibrates and shifting into second is really hard like i dont have the clutch released or anything...i tried to speed shift and first from second will not go into gear unless i slow down..someone said maybe the springs on the clutch are softing up?? also i was in 4th and tried to release the clutch and nothing happened it just kept on driving..and when i pulled over it was in frist at a stop and it started rolling and vibrating like i was letting off the clutch but i wasnt..anyone had this problem before???
Old Feb 4, 2004 | 10:24 AM
Dan GSR's Avatar
Default Re: help with tranny problem!! (P73typeR)
guarantee that your clutch is blown up
your symptoms tell me that , that is what is wrong
buy a new clutch kit
you going to have to buy a clutch disc and pressure plate, and depending on how long you've been driving, u may have damaged the flywheel
Old Feb 4, 2004 | 10:27 AM
florduhdude's Avatar
Default Re: help with tranny problem!! (Dan GSR)
What year model? If it's got a hydaulic clutch check the clutch reservoir fluid level
Old Feb 4, 2004 | 10:32 AM
B18CmeFLYby's Avatar
yup,clutch is gone, same thing happened to me.
Old Feb 4, 2004 | 10:34 AM
P73typeR's Avatar
the fluids are all fine and everything im bout to get a new clutch and hopefully thats the problem i hope that the tranny isnt jacked up...also im gonna get that flywheel lightened hopefully that isnt damaged...thank u guys for ur help
Old Feb 4, 2004 | 10:35 AM
yellow_jacket's Avatar
Default Re: (B18CmeFLYby)
First check your hydraulics. If they are good to go, rip the clutch out.
Same happend to me, clutch is gone.
Old Feb 4, 2004 | 10:37 AM
P73typeR's Avatar
oh and my car is a 95 gsr with 140000 miles on the chassis but only like 1100 on the motor...i havent had the car that long only a month and i got the motor rebuilt but i dont know if the clutch or anything has ever been changed im sure it hasnt with the way that it is running.
Old Feb 4, 2004 | 10:39 AM
P73typeR's Avatar
what clutch kit do yall recommend? i was thinking exedy stage 1 kit...my cars puttin out like almost 170 whp..i dont really know much bout a good clutch or not
Old Feb 4, 2004 | 10:41 AM
Most mechanics will change the clutch when they rebuild or install a motor.
Just because you have fluid in the resevoir, doesn't mean thehydraulics are good. Check to make sure the slave cylinder is actually moving the fork a decent amount.
Old Feb 4, 2004 | 10:42 AM
Dan GSR's Avatar
I'm using the exedy
and i like it
good bang for the buck
Old Feb 4, 2004 | 10:44 AM
P73typeR's Avatar
Default Re: help with tranny problem!! (yellow_jacket)
i dont know how to check the hydraulics or anything when i take it in ill have them check it because i need to get a stronger clutch anyways but thanks for ur help...
Old Feb 4, 2004 | 11:02 AM
msmithgsr2131's Avatar
About a month ago I had that exact same problem in my GSR, but then I replaced my transmission fluid and about a week later it was fine, gears go in smoooooth again.
Old Feb 4, 2004 | 11:20 AM
P73typeR's Avatar
Default Re: help with tranny problem!! (msmithgsr2131)
see i just changed my fluid like 2 days ago..
supereg2
Mar 21, 2008 09:51 AM
GoKOOLjeff
Nov 5, 2006 09:01 PM
mawkiemarc
Aug 1, 2005 08:41 PM
LowAcura
Apr 20, 2003 04:30 PM
J-Brooks
Dec 17, 2002 10:23 AM
