HELP...Transmission problem
Old Jun 8, 2004 | 04:16 PM
ITR Buddy's Avatar
Default HELP...Transmission problem
Sup everyone. I cant engage nor disengage into any gears while the car is on. But when the car is off its prefectly fine. So then i started the car in 1st gear with the clutch down and moved it and everything seemed fine but still no luck getting out of the gear. I already bled the clutch and did the tranny fluid. The clutch pedal feels fine also. Any solutions? Its on a 98 itr with 26k miles.
Old Jun 8, 2004 | 05:10 PM
JiggyKooAndy's Avatar
Default Re: HELP...Transmission problem (ITR Buddy)
sounds like you might have popped a spring in your clutch disc. It definately sounds like a clutch problem though...
Old Jun 8, 2004 | 05:33 PM
FerioVtec94's Avatar
hes right, gotta be the clutch, this is usually diagnosed when you can go thru the gears when the car is off but not when its on
Old Jun 8, 2004 | 05:43 PM
Default Re: (FerioVtec94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FerioVtec94 &raquo;</TD></TR><TR><TD CLASS="quote">hes right, gotta be the clutch, this is usually diagnosed when you can go thru the gears when the car is off but not when its on</TD></TR></TABLE>
yup, that is correct
Old Jun 8, 2004 | 08:29 PM
ITR Buddy's Avatar
Default Re: (JiggyKooAndy)
i c...cuz we thought it was the synchros but what were the chances of breaking all of them at once. Is this a problem that many people get with stock clutches or did i hit the jackpot? Any recommendation on clutches just as a stock replacement? thx everyone
Old Jun 8, 2004 | 08:50 PM
same thing happened to my roomate, his started worsening gradually though, he would have to turn the car off at every stop light to put it in first gear and then once the car was moving it was driveable but barely and grinded at time...changed his clutch and it fixed everything
i've had several friends who have had this same problem when their clutches go out
I've always used ACT clutches and have never had any problems
Old Jun 8, 2004 | 09:04 PM
Blind-Fashion's Avatar
i would definatly get it fixed before you **** up your tranny man.
Old Jun 8, 2004 | 09:41 PM
lotus's Avatar
New User
Default Re: (Blind Fashion)
I just did the ACT hdss clutch / pressure plate combo ( mind you also with the pro lite flywheel )
and so far I really like the clutch. it grabs hard, but the pedal is not very stiff at all.
Old Jun 9, 2004 | 12:39 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FerioVtec94 &raquo;</TD></TR><TR><TD CLASS="quote">same thing happened to my roomate, his started worsening gradually though, he would have to turn the car off at every stop light to put it in first gear and then once the car was moving it was driveable but barely and grinded at time...changed his clutch and it fixed everything
I've always used ACT clutches and have never had any problems</TD></TR></TABLE>
same thing happened with me. It just got worse and worse, and i couldn't shift at any rpm over 3000. I thought it was the throwout bearing...so i went out and bought an exedy clutch kit (i love it); and when i got my tranny out, i found out that i had infact popped a spring in my clutch disc, and part of the metal on the clutch disc was floating around inside the bellhousing with the clutch and whatnot. That was one fucked up clutch
My advice...go buy an ACT or exedy clutch kit...pull your tranny and u'll soon find out what the problem is
Old Jun 12, 2004 | 07:45 PM
ITR Buddy's Avatar
we took out the tranny and found that the clutch maybe has 1/3 of its life left, huge amount of hotspots on the pressure plate and flywheel. The tranny itself has tiny small cracks/lines everywhere but could that be part of the casting mold ( the area around the fork)? Also it look pretty greasy like tranny fluid somehow got into that area and it eventually got caked on. Any ideas?
Old Jun 12, 2004 | 08:59 PM
ITR Buddy's Avatar
bump
Old Jun 13, 2004 | 03:45 PM
ITR Buddy's Avatar
bump.. anyone?
alexsneesby
Aug 18, 2010 12:11 PM
civicsi18
Transmission & Drivetrain
Aug 16, 2008 08:11 AM
esoterEK..
Oct 5, 2003 09:19 PM
92 civic VX B18c
Sep 30, 2003 03:34 AM
erikgsr
Apr 6, 2003 12:03 PM
