Charcoal Can Bypass?
Old Nov 5, 2006 | 07:43 PM
EKHWhat's Avatar
Default Charcoal Can Bypass?
Ive got a EK I just swapped a H22 into and, it being a track-only car, I'd like to take the charcoal can out.
Im wondering what hoses will have to be ran together to make this happen and all that.
Old Nov 5, 2006 | 07:51 PM
f20bej1's Avatar
Default Re: Charcoal Can Bypass? (EKHWhat)
charcoal can ?
Old Nov 5, 2006 | 08:20 PM
EG2Driver's Avatar
Default Re: Charcoal Can Bypass? (f20b eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by f20b eg &raquo;</TD></TR><TR><TD CLASS="quote">charcoal can ? </TD></TR></TABLE>
on the back of the block, a black rectangle. Has to do with emission control.
Old Nov 5, 2006 | 08:35 PM
VtecnTurbo's Avatar
Default Re: Charcoal Can Bypass? (DeadEnd9009)
its ok if your stock if you have engine mads or plan on upgrading block it off and vent the valve cover
Old Nov 5, 2006 | 08:49 PM
Eran's Avatar
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeadEnd9009 &raquo;</TD></TR><TR><TD CLASS="quote">on the back of the block, a black rectangle. Has to do with emission control.</TD></TR></TABLE>
No, you're thinking of the oil separator. The charcoal canister is on the firewall, and it's for evap emissions (fuel).
Old Nov 5, 2006 | 08:53 PM
EG2Driver's Avatar
Default Re: Charcoal Can Bypass? (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">No, you're thinking of the oil separator. The charcoal canister is on the firewall, and it's for evap emissions (fuel).</TD></TR></TABLE>
thanks for straightening a man out.
Old Nov 5, 2006 | 10:16 PM
ED9man's Avatar
Just take it out and plug the IM. You'll have a hose coming out of your firewall which is where the fuel vapors will vent.
Old Mar 12, 2007 | 02:01 PM
g2_teg_'s Avatar
Default Re: (ED9man)
if i am removing my emissions charcoal canister, do i still need the Evaporitive Emissions (EVAP) purge control solenoid valve? If I remove that, will i get a CEL (OBD1)? I noticed that it is on my engine wire harness.
Old Mar 12, 2007 | 05:24 PM
matt da jdm junkie's Avatar
yea u probally will but it is obd1 so u can clear the code and turn the check light off
Old Mar 12, 2007 | 06:09 PM
g2_teg_'s Avatar
Default Re: (matt da jdm junkie)
wont it just come back on everytime i drive? Anybody know how to prevent the CEL from coming on?
Old Mar 12, 2007 | 06:48 PM
92ehatch's Avatar
Default Re: (g2_teg_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g2_teg_ &raquo;</TD></TR><TR><TD CLASS="quote">wont it just come back on everytime i drive? Anybody know how to prevent the CEL from coming on?</TD></TR></TABLE>
i just left it there, plugged in, but capped all vacuum lines.
no cel. no purge solenoid (physicall it is still mounted)
Old Mar 12, 2007 | 06:54 PM
93eg2james's Avatar
Default Re: (92ehatch)
I wanted to know this as well. I was going to remove my evap purge valve completely, But I was pretty sure I was going to get a cel... :-(
Old Mar 13, 2007 | 10:38 AM
g2_teg_'s Avatar
Default Re: (93eg2james)
if the car ran, i would just freakin unplug it and see what happens. but im trying to make the wire harness for it and i cant really test it anyway...
Old Mar 13, 2007 | 06:20 PM
93eg2james's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g2_teg_ &raquo;</TD></TR><TR><TD CLASS="quote">if the car ran, i would just freakin unplug it and see what happens. but im trying to make the wire harness for it and i cant really test it anyway...</TD></TR></TABLE>
You'd get a CEL. Tried it today.
Old Mar 14, 2007 | 11:09 AM
g2_teg_'s Avatar
thank you, kind sir.
now. on to my next question, if i keep it, will just plugging it work?
Old Mar 14, 2007 | 11:16 AM
YoungKadafi's Avatar
negative. If you have OBD1 your good. OBD2 you will get a CEL every 3-4 days or so..
As far as I know, anything over 1996 has more than just a solenoid, so like a 1996 coupe, and 97+ has like 4 different sensors, which only way to bypass is to convert to OBD1.
Plug the IM port, and route the fuel hard line into the large hose port under the battery.
https://honda-tech.com/zerothread?id=1920033
Old Mar 14, 2007 | 11:19 AM
however a VERY good work around is to somehow rig up a vac pump, and not only hooking your PCV system up to it, connect the EVAP solenoid to it, that way it will register air is still being sucked into the solenoid. NO CEL then. however if somebody knows a ressitor mod that would be awsome to trick the solenoid. I know u can with the knock sensor and 2nd o2
Old Mar 14, 2007 | 05:32 PM
g2_teg_'s Avatar
Default Re: (YoungKadafi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YoungKadafi &raquo;</TD></TR><TR><TD CLASS="quote">however a VERY good work around is to somehow rig up a vac pump, and not only hooking your PCV system up to it, connect the EVAP solenoid to it, that way it will register air is still being sucked into the solenoid. NO CEL then. however if somebody knows a ressitor mod that would be awsome to trick the solenoid. I know u can with the knock sensor and 2nd o2</TD></TR></TABLE>
thats really what i was looking for... so obd-1 will get no code? thats all im worried about then... thank you.
Old Mar 15, 2007 | 09:57 AM
another work around is to just run the hard line, to the evap solenoid, to the cruise control port. This way you can unmount the solenoid from the the fuel rail. Move it underneather the IM, not get a cel, and still have the same MPG. Ive noticed without the evap system, my MPG SUCKS!!! im getting about 26 mpg right now, from 35.
I usually spend about $10 gas a week, now im dropping $10 every 3 days.
Old Mar 15, 2007 | 11:49 AM
g2_teg_'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YoungKadafi &raquo;</TD></TR><TR><TD CLASS="quote">another work around is to just run the hard line, to the evap solenoid, to the cruise control port. This way you can unmount the solenoid from the the fuel rail. Move it underneather the IM, not get a cel, and still have the same MPG. Ive noticed without the evap system, my MPG SUCKS!!! im getting about 26 mpg right now, from 35.
I usually spend about $10 gas a week, now im dropping $10 every 3 days.</TD></TR></TABLE>
should i just plug the hose coming from the bottom of the solenoid?
Old Mar 15, 2007 | 12:52 PM
no dont plug any solenoid port. You wanna run a hose from the fuel line, to the solenoid, to the IM port, or cruise control port. this way you still have the fuel vapors, but its hidden.
the only thing you need to plug, is the IM port your not using.
saintspall
15
Mar 2, 2007 03:17 AM
94IntegraLs04
15
Sep 16, 2006 11:42 AM
ppfalcon
Jun 15, 2005 09:46 AM
Lu DC2
Feb 25, 2005 06:13 AM
Irishweird00
Dec 10, 2003 11:30 PM
