CODE 10 (IAT) ON B20VTEC SWAP!!
Old Nov 5, 2006 | 04:14 PM
SpoonEk253's Avatar
Default CODE 10 (IAT) ON B20VTEC SWAP!!
This is the only code i cant get rid of....i've replaced the old sensor because it was like burnt. now i just installed a new IAT, but the code still shows up...i've even reset my ecu no luck....any idea's? If this helps im using a 98ex harness w/ a gsr head and jdm p30 ecu.
Old Nov 6, 2006 | 07:00 PM
SpoonEk253's Avatar
Default Re: CODE 10 (IAT) ON B20VTEC SWAP!! (SpoonEk253)
help?
Old Nov 7, 2006 | 01:14 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: CODE 10 (SpoonEk253)
check continuity from the sensor to the ECU
Old Nov 8, 2006 | 06:09 AM
JamesParker's Avatar
You probably have the wrong connector pluged into the IAT! Been there done that. Check the sensor again and check the wire colors with a schematic. I'd put money on it that you have the wrong connector plugged into the IAT.
Old Nov 8, 2006 | 03:44 PM
SpoonEk253's Avatar
Default Re: CODE 10 (JamesParker)
the colors on the wires that i plug'd into the IAT is black/green and the colors i got in my IACV is yellow/black, then the colors i got goin to the black cansiter is black/blue....im pretty sure they are the right ones....there arent any other plugs that can reach that far or fit.
mouab18c1
Feb 23, 2009 09:08 AM
SpoonEk253
Nov 8, 2006 08:12 PM
silentblackhat
May 1, 2005 04:41 PM
THE94GSR
Jun 25, 2004 05:07 AM
99blackvti
May 24, 2004 07:06 PM
