step deck machining
Old Nov 4, 2006 | 07:11 PM
mrbh22's Avatar
Default step deck machining
i was just told about step deck machining and was wondering what exactally it means? i just got my h22 block back from rs machine. and the sleeves are out a little bit farther than the actual deck height. i know thet they are like that for a reason. i was just wondering what height i should have it decked to? check sig for info about setup. thanks in advance!
Old Nov 5, 2006 | 03:02 AM
Danny_EJ's Avatar
its when the sleeves are higher than the rest of the deck surface by a few thousanths to help the head gasket seal better. I dont know the specs you'd have to talk to someone who sleeves engines
Old Nov 5, 2006 | 07:58 AM
mrbh22's Avatar
Default Re: (Danny_EJ)
thanks. bump for any more info? like specs on h22?
Old Nov 5, 2006 | 04:32 PM
b18sihatch's Avatar
Default Re: (mrbh22)
i believe benson does the step decking
Old Nov 5, 2006 | 06:51 PM
PrettyLude's Avatar
benson doesn't do the step deck option anymore. due to the fact that it doesn't seal well
Old Nov 5, 2006 | 08:11 PM
b18sihatch's Avatar
Default Re: (PrettyLude)
i didnt think they did anymore but i remember reading that they used to
Old Nov 5, 2006 | 08:37 PM
Garage 808 Hatch's Avatar
GE still does, but i think its like .001"
Old Nov 5, 2006 | 08:46 PM
mrbh22's Avatar
Default Re: (Garage 808 Hatch)
thanks for the info. i have yet to do the final machining... i heard that it helps seal the motor when it is step decked> and benson isnt doing it anymore ecause it doesnt seal well>?? can someone with expierence let me know there exp. ?
Old Nov 5, 2006 | 08:56 PM
b18sihatch's Avatar
the gist of it is that the sleeves are machined very little bit taller than the rest of the block so when the head is on the sleeves are slightly slightly pressed up into the head, supposed to seal it better, however i really dont feel this is needed.
Old Nov 5, 2006 | 09:20 PM
mrbh22's Avatar
Default Re: (b18sihatch)
does anyone have expierence on this with an h22?? getting the machining done friday and would really appreciate any knowledge! thanks
Old Nov 6, 2006 | 01:22 PM
mrbh22's Avatar
bump
Old Nov 7, 2006 | 07:11 PM
mrbh22's Avatar
bump need someone with expierence's info
Old Nov 7, 2006 | 09:44 PM
SoOHiGH's Avatar
i'd rather get mines o-ringed then step deck.
Old Nov 8, 2006 | 08:27 AM
Default Re: (SoOHiGH)
you have to replace the o-rings if u pull it apart. granted it is only copper wire. you dont have to replace the stepped deck
Old Nov 8, 2006 | 08:33 AM
b18sihatch's Avatar
Default Re: step deck machining (mrbh22)
i dont see why you want to step deck or o ring the block, its not needed, its not a must.
IMO its more trouble than its worth
Schister66
May 20, 2016 05:45 AM
turboD_EG
Nov 19, 2008 05:59 AM
rollercosta123
Nov 8, 2006 11:04 AM
IntegraGSR(-1)
May 9, 2006 10:31 AM
stock92prelude
Sep 18, 2003 11:09 PM
