Is It Actually Possible To Remove Alternator From Top Of Engine Bay???
Old Nov 4, 2006 | 01:35 PM
b18cEK's Avatar
Default Is It Actually Possible To Remove Alternator From Top Of Engine Bay???
as the topic states, in a 97 ex...
I tried for a good hour and I can't seem to figure it out!
Old Nov 4, 2006 | 01:39 PM
ekb16's Avatar
its possible but u will prob scrape up a few stuff...ive dont it with my b16 in ek b4
Old Nov 4, 2006 | 01:45 PM
NJcoupe's Avatar
Default Re: (ekb16)
you have to take the fuel rail and **** off. just drop it out the bottom.
Old Nov 4, 2006 | 01:47 PM
b18cEK's Avatar
Default Re: (dxcoupe.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dxcoupe. &raquo;</TD></TR><TR><TD CLASS="quote">you have to take the fuel rail and **** off. just drop it out the bottom.</TD></TR></TABLE>
dont i have to take off the axle tho? if so, how long does that take if you have never done it before?
Old Nov 4, 2006 | 02:28 PM
fdjizm's Avatar
take the brake master cylinder off the firewall, done take off lines, just bolts that hole it to the car..
Old Nov 4, 2006 | 03:56 PM
b18cEK's Avatar
Default Re: Is It Actually Possible To Remove Alternator From Top Of Engine Bay??? (ej8pwr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fdjizm &raquo;</TD></TR><TR><TD CLASS="quote">take the brake master cylinder off the firewall, done take off lines, just bolts that hole it to the car..</TD></TR></TABLE>
hmm.. goin to have to try that.
Old Nov 4, 2006 | 08:31 PM
hondavet's Avatar
MAN! You don't have to take off ****! If you position it just right it will come out over the axle and through the wheel well. Just get that splash shield out of the way.
Old Nov 4, 2006 | 08:37 PM
Orangecivic251's Avatar
Default Re: Is It Actually Possible To Remove Alternator From Top Of Engine Bay??? (hondavet)
no you guys obviously can't manouver. just pull it and remeove the master cylinder
Old Nov 4, 2006 | 08:51 PM
F20Cteg's Avatar
Default Re: Is It Actually Possible To Remove Alternator From Top Of Engine Bay??? (HondaEMS.com)
Remove the master cylinder?
God this site is going downhill.
Although it makes me laugh which is good.
Old Nov 5, 2006 | 06:44 PM
Default Re: Is It Actually Possible To Remove Alternator From Top Of Engine Bay??? (F20Cteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by F20Cteg &raquo;</TD></TR><TR><TD CLASS="quote">Remove the master cylinder?
Although it makes me laugh which is good.</TD></TR></TABLE> you haven;t been here long enough to say it's going down hill and yes if i can't wiggle y alternator for some reason i have removed the MC before on my old delsol
Old Nov 5, 2006 | 06:53 PM
EG2Driver's Avatar
remove the bracket that holds it on the engine block. It should drop from the bottom.
This is from experience on a D series OBD-1
Old Nov 5, 2006 | 06:57 PM
slambedcivic's Avatar
Default Re: Is It Actually Possible To Remove Alternator From Top Of Engine Bay??? (DeadEnd9009)
umm. i dont know about all of these things you guys are saying. ive pulled alternators from the top. its the only way i usually do them.
Old Nov 5, 2006 | 06:58 PM
Archidictus's Avatar
Unceasing Measure
Default Re: Is It Actually Possible To Remove Alternator From Top Of Engine Bay??? (slambedcivic)
I pull them from the top via the "loosened master cylinder" approach. Never failed me. Not sure what the great debate is all about.
Old Nov 5, 2006 | 07:18 PM
Default Re: Is It Actually Possible To Remove Alternator From Top Of Engine Bay??? (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">I pull them from the top via the "loosened master cylinder" approach. Never failed me. Not sure what the great debate is all about.</TD></TR></TABLE> thank you!
Old Nov 5, 2006 | 07:53 PM
EFbomb's Avatar
take the bolts off
take the belt off
go for a drive
it will find its way out
Old Nov 5, 2006 | 07:58 PM
EX-T's Avatar
Default Re: (EFbomb)
Honda would tell you to remove the axle and pull it out that way. But I would loosen the brake master cylinder and pull it out through there...
Old Nov 5, 2006 | 09:45 PM
F20Cteg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaEMS.com &raquo;</TD></TR><TR><TD CLASS="quote"> you haven;t been here long enough to say it's going down hill and yes if i can't wiggle y alternator for some reason i have removed the MC before on my old delsol</TD></TR></TABLE>
Been here way longer, my current join date doesn't mean anything.
Old Nov 6, 2006 | 03:53 AM
b18cEK's Avatar
Default Re: (EX-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EX-T &raquo;</TD></TR><TR><TD CLASS="quote">Honda would tell you to remove the axle and pull it out that way. But I would loosen the brake master cylinder and pull it out through there...</TD></TR></TABLE>
this method worked!
thanks guys
EK4_K20
Jan 30, 2008 01:18 PM
carlthecrx
21
Nov 11, 2007 03:22 PM
J.P. 4rm The dPk*
Aug 30, 2005 02:32 PM
kaotikcrx05
Jan 27, 2005 10:11 AM
jDMJeRk
Nov 29, 2004 04:53 PM
