1993 Del Sol Heater Fan Problem
My Heater fan does not work on speed 1 and 2 but works fine on 3 and 4. I replaced the fan but the problem followed.
Could it be Blown Resistors or is there a unit that controls the fan speed? I am assuming there is something to cut voltage to the fan to lower and raise the speed. Any input would be great.
Guess whos bizzack
Re: 1993 Del Sol Heater Fan Problem (underpressure02)
try replacing the solenoid just like tom cruise did in war of the worlds, watch out though you will have the only running car on planet earth then
chad check the controller behind dash were the switch is, there should be a box back there, (cant remember what its called) and id ont have any spare ones i dont think? unless civic is the same and in that case i got them
d
d
Re: 1993 Del Sol Heater Fan Problem (nasteboyii)
Fixed it today. It was the resistor. Took the glove box out and unscrewed the two screwes put the new one in and it was good to go.
