B16 swap questions?
Old Nov 4, 2006 | 10:27 AM
crxpwr1's Avatar
Default B16 swap questions?
Which map do I use the one that came with the car or the one that came with the motor? Also I would like pics of a b16 swap so I can figure out where all the hoses run and stuff like that...I would like the pics at different angles to thanks in advance
I would also like to know what kind of oil do you use....I wont be able to crank it for another couple months but I drained the oil because I got bored one day and I heard if you leave an engine sitting with out oil it could do some damage. How much oil does it take to fill it up to?
Modified by crxpwr1 at 11:46 AM 11/4/2006
Old Nov 4, 2006 | 08:26 PM
crxpwr1's Avatar
Default Re: B16 swap questions? (crxpwr1)
Old Nov 4, 2006 | 09:10 PM
joethejoeman's Avatar
r u talking about wiring, use the wiring harness that came with the car,
then use a sub harness for vtec selonid, oil pressure, knock sensor, o2,
then switch the ecu box thing,
um hoses, which hoses r u talking bout
Old Nov 4, 2006 | 09:12 PM
crx_gsr_vtec's Avatar
use the one that came on the motor block your vacum hose and extend the map sensor wires from the crx firwall to the throttle body map.
Old Nov 4, 2006 | 09:23 PM
Default Re: (crx_gsr_vtec)
make sure ur radiator hose, and ur throttle cable fit too,
i did my swap and i had to replace them.
Old Nov 5, 2006 | 10:28 AM
crxpwr1's Avatar
Default Re: (joethejoeman)
k all I need is a pic so I can see where all the hoses run to that are cut and what they are used for because I have a bunch of cut hoses....also I sent my wiring off to rywire so I know it was done right but I forgot what map to use the one thats on the car or the one that came with the b16
Old Nov 5, 2006 | 03:21 PM
crxpwr1's Avatar
Default Re: (crxpwr1)
Old Nov 5, 2006 | 03:35 PM
aaronhume's Avatar
you fill it up til the top dot on the dipstick
just think logically about your hoses and make sure theres nothing let without hoses on it.
you might want to do more research before you buy an engine in the future
Old Nov 10, 2006 | 08:44 AM
Nohginmonster's Avatar
Default Re: B16 swap questions? (aaronhume)
I can't remember whether or not the headers have clearance issues with the front crossmemember on my 89si', or any crx in general?
I want to find out before the install.
Old Nov 10, 2006 | 10:30 AM
crxpwr1's Avatar
Default Re: B16 swap questions? (Nohginmonster)
no im using a 4-2-1 and i had to take mine apart then fit it because when it was together I couldnt get it in there but it was a good fit
Old Nov 10, 2006 | 11:40 AM
NikoZai's Avatar
B16 Vacuum Diagram: http://rywire.com/store/faqdes...id=15
Old Nov 10, 2006 | 12:55 PM
Default Re: B16 swap questions? (NikoZai)
Thanks!
Got the sub-harness and also found out that stock headers will clear the crossmember.
What headers don't fit and for future reference, does anyone know where I could acquire an aftermarket front crossmember?
EF9_TryMe
Dec 13, 2010 08:55 AM
:::SIRll_EJ1:::
Mar 10, 2010 02:43 PM
ek9si
Mar 17, 2009 12:49 AM
potpot2x
May 5, 2008 12:47 PM
onefastx
Oct 25, 2006 04:09 AM
