00 d16y8 civic ex tranny 5 speed on 95 civic ex?
Old Nov 4, 2006 | 08:06 AM
Sketch_hs's Avatar
Default 00 d16y8 civic ex tranny 5 speed on 95 civic ex?
My friends car needs a new tranny today
i found a 2000 d16y8 civic ex tranny 5 speed for a good price, will everything bolt up perfect or no?
-Ty
Old Nov 4, 2006 | 08:08 AM
Bense's Avatar
yes, enjoy the 0.4% shorter 2nd gear.
Old Nov 4, 2006 | 08:13 AM
Sketch_hs's Avatar
anything else i should know?
all the sensors plug in and stuff?
same axles?
same shift linkage?
same mounting?
Old Nov 4, 2006 | 08:15 AM
cbmprelude's Avatar
* B A N N E D *
Default Re: (Sketch_hs)
yea but you will need the passenger side upper tranny mount to go with it. Bense please correct if I am wrong. I had to do this when I swapped a 95 si tranny onto my 98 cx
Old Nov 5, 2006 | 04:30 PM
Sketch_hs's Avatar
thanks all
found a jdm d15b vtec LSD tranny for the car for $450 and 60000 kilometers verified
Old Nov 5, 2006 | 04:51 PM
Bense's Avatar
everything bolts up the same. only difference is the shifter forks and the synchro sleeves (because they touch the synchro forks) also the cage on one of the countershaft bearings is different
yes, everything is the same. i'm using a y8 trans on my d15b right now.
mounts are the same as when I had my z6 trans on there.
Old Nov 5, 2006 | 05:05 PM
cbmprelude's Avatar
* B A N N E D *
Default Re: (Bense)
hmm the non si/ex trams use diff cases maybe that is the mount difference?
Old Nov 5, 2006 | 05:25 PM
Bense's Avatar
there's 3 holes on the trans housing. 2 holes have studs, one hole has a bolt. maybe a bolt / stud was swapped?
Unseen Racer
11
Aug 2, 2009 10:29 PM
924doorEG
May 13, 2008 12:41 PM
burge
Mar 16, 2007 05:42 PM
jdm_eg
Dec 21, 2004 06:46 AM
EK45VTi
Sep 13, 2004 10:58 AM
