e-brake light always on
check to make sure something isnt grounding out the switch under the ebrake handle and also check to make sure that your master and slave cynlinders are at the correct level of fluid.. if these things check out you have a bad switch or wiring problem under the dash..
CRX T-Si
16
Jun 23, 2006 11:30 PM
