how do i fix my shifter??
Old Nov 1, 2006 | 06:20 AM
slammed94ferio's Avatar
Default how do i fix my shifter??
hey guys, i'm new to honda-tech and the scene of fixing up my civic. i just bought my first car which was a 94 4dr dx. There are some small problems with it that i'm hoping are easy to fix. I was told that it was a short shifter but after buying the car and taking apart the console i discovered that its not an actual short shifter they just cut the ****, and now for some reason or another the shifter leans to the left. its not that big of a deal but shifting from 3rd to 4th sometimes is tricky if i'm not paying attention. when i wanna go into 4th it will go straight to 2nd if i dont pull to the right when shifting.......how can i fix this????
Old Nov 1, 2006 | 04:05 PM
honda_power69's Avatar
Get the car on a lift (if you have access to one) or put it on jackstands and get underneath it. Directly under where the shifter would be inside the cabin you should be able to see it coming thru the floorboard, the exhaust being in the way might make it tricky to see. There is a rubber bushing that has two bolts in it that actually holds the shifter stick, check to make sure its not missing a bolt or ripped/torn. This bushing will be towards the top of the shifter stick, above where the shift linkage bolts to the lever.
Old Nov 3, 2006 | 06:36 AM
Default Re: (honda_power69)
thanks man, i'll see if i can find the time this weekend. i'll keep ya posted if your interested in how it turns out.
Dkahn18
Welding / Fabrication
13
Dec 28, 2008 09:38 PM
Draggin99Si
Jul 30, 2007 08:22 AM
LaloQuera
Oct 3, 2006 12:34 PM
slash00R
Nov 1, 2004 07:23 PM
SOHCit2ME
Aug 24, 2001 01:11 PM
