thermostat starting to stick
Old Nov 1, 2006 | 06:54 PM
bmw626's Avatar
Default thermostat starting to stick
so today i am driving on the freeway (boosted built sohc 5psi) and i notice my temp gauge jacks up from alitte under half to 3/4 way to "H" on my coolant temp gauge (stock gauges) and i was like wtf so i ease up and coast for about a mile or 2 and it wouldn't let up. so a min later it goes up alittle more then all of a sudden it drops. well like 2 min later it did it again and i was like wtf again. its never done this to me before. so is my thermostat sticking or do i need to beef up my cooling system? and if i need to get a new thermostat, should i just get a lower temp one (160F opposed to stock 190F) or would that not be a good idea for winter (i live in NC, moderate winters) thanks
Old Nov 1, 2006 | 06:58 PM
ftnjun2x's Avatar
Default Re: thermostat starting to stick (bmw626)
mod list?
Old Nov 1, 2006 | 07:04 PM
bmw626's Avatar
Default Re: thermostat starting to stick (ftnjun2x)
d16z6 block / jdm d15b head
eagle rods
srp pistons
acl bearings
all new gaskets and seals
new oil pump & waterpump
dsm 450cc injectors
phearable basemap (crome)
arp headstuds
greddy 15g turbo stock 5.5psi
precision 350hp intercooler
greddy type rs bov
walbro 255 fuel pump
exedy stage 2 racing clutch kit
thats all i can think off of the top of my head
Old Nov 2, 2006 | 06:12 AM
bmw626's Avatar
bump
Old Nov 2, 2006 | 11:06 AM
bmw626's Avatar
ummm help?
Old Nov 2, 2006 | 12:09 PM
Perfectionist's Avatar
Might be a sticky T stat. OEM stats have worked the best for me. I don't think getting a cooler stat is wise. Stay with the stock temp.
Might also be a bad thermostat ground, temp sensor, or air in the cooling system.
Old Nov 3, 2006 | 06:39 AM
bmw626's Avatar
Default Re: thermostat starting to stick (Perfectionist)
my thermostat ground came loose the other day when i was on the freeway and the car just sputtered and died and i went through checkign all my fuses and grounds and i found it was loose and i just hand tightened it and its been being gay since. i tightened it with a wrench since. should i take it off and clean the connections up?
Emilytcivic
Honda Civic (2006 - 2015)
Nov 22, 2014 04:54 AM
Kid-jdm-teggy
Mar 23, 2014 06:31 PM
da_33
Nov 30, 2006 08:29 PM
5thgencivic
May 26, 2003 06:11 PM
DeDonDeRosa
May 18, 2003 07:36 AM
