What is the best method to remove surface rust from metal?
Hi all!
I just bought a used hitch, but it has alot of surface rust on it. Whats the best/most cost effective way to clean off all the rust?
I was thinking of sand-blasting. Anyone have any idea how much it might cost?
What other methods do you guys suggest? What type of paint should I spray it with when I am finished to prevent it from rusting again?
Sand blasting that will take about 10min. & it will be done to perfection, if you use a wire wheel, you could spend hours on it if it's pitted at all.
I run a powder coating shop out of my garage & i did something like that for someone b4, blasting costed them 20 bucks & powder coated it for 50. I'm sure you could find someone local to you to blast it for you & then you could just paint it if you wanted.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Running925 »</TD></TR><TR><TD CLASS="quote">
I run a powder coating shop out of my garage & i did something like that for someone b4, blasting costed them 20 bucks & powder coated it for 50. I'm sure you could find someone local to you to blast it for you & then you could just paint it if you wanted.</TD></TR></TABLE>
Was that your price $20 for sandblasing, or thats the normal price?
the guy I use would cost about $10 to blast and prob about $50 total with it painted black with some industrial paint or bout $60-70 powder coated
thats what i would charge but thats about going rate. I primarily do powder coating but i offer the blasting service to those that are unable to prep their own materials.
media blasting it will take it right down to metal
If you have a electric angle grinder or an air angle grinder, get some of those 3M pads, grind it all off
there was alot of surface rush on a lift at work, and i just grinded it all off with that... easiest
