code 43 and 22 ???
i have a 92 civic hatchback si with the stock z6. it has intake, mild headwork, header, and exhaust. when i get around 6 grand or higher in second gear and shift into third fast the CEL comes on. i checked the codes and it was 43(fuel supply system) and 22(oil pressure switch). when i turn the key off and back on it gos away.
when i bought the car a week ago the kid told me in need a vtec silenoid and i had one laying around that i knew worked so i put it on and didnt make any diffrence.
i was reading about code 43 and put a fuel pressure gauge on to check the fpr becouse it was easyist to check and it was fine.
the car dosnt run bad i just dont know why it would throw code 43 and 22 at the same time and both go away when i shut off the car. should i try taking the neg off the battery sence i changed the whole silenoid and pressure switch and if so whould it have anything to do with the fuel supply system cel at all?
bump!! i got the same problem, i did a mini me swap, with a z6 head on an a6 block, didnt know i was suppose to take the oil pressure fitting out of the block to make the vtec work, so i have to pull the head again and do it but, when mine get over 6k its sputter like no fuel or somethin and now its throwin a 43 and 22??? anyone know whats up?
DC5ftmfw
Mar 12, 2007 06:52 PM
