mini me help
Old Oct 31, 2006 | 04:19 AM
EkLanta's Avatar
Default mini me help
Okay I recently bought a d16y8 head and I have a y7 block. Is the mini me swap as easy as switching everything off the head and putting intake manifold and exhaust headers back on?
Old Oct 31, 2006 | 04:45 AM
vaypourus's Avatar
Default Re: mini me help (EkLanta)
make sure you pull the oil jet restrictor, or you won't have any oil to activate the VTEC.
Old Oct 31, 2006 | 04:58 AM
jjspec's Avatar
Default Re: mini me help (vaypourus)
you may have to use a combination of head bolts between the engines .
Old Oct 31, 2006 | 06:43 AM
EkLanta's Avatar
Is that all that I need?
Old Oct 31, 2006 | 09:35 AM
vaypourus's Avatar
Mine turned out to be a big project; I ended up buying:
new vtec distributor
new vtec compatable wires
new plugs for the 1.6 head
head gasket
head studs
intake & exhaust mani gaskets
new water pump (might as well while you are in there)
new timing belt
modified ECU
other stuff I can't think of right now.
You are going to have some other issues with that head...the Z6 is more of a direct swap for a 92-95 d15 than the later heads/block combinations.
Old Oct 31, 2006 | 10:01 AM
EkLanta's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vaypourus &raquo;</TD></TR><TR><TD CLASS="quote">Mine turned out to be a big project; I ended up buying:
head gasket
head studs
new timing belt
modified ECU
You are going to have some other issues with that head...the Z6 is more of a direct swap for a 92-95 d15 than the later heads/block combinations.</TD></TR></TABLE>
thanks
sony224422
Sep 25, 2015 10:50 AM
Radim
Sep 1, 2008 09:15 PM
SHG_Beans
Nov 15, 2005 06:16 PM
richie_vei_uk
Sep 10, 2003 09:23 PM
alphaquake
Jul 18, 2002 03:35 AM
