D15z1 Head swap
D15z1 Head swap
Im from the UK and I have a D15z1 Vei and am looking to swap the head for a D16z6 (ESi) head i was wondering what items i would need to do the head stuff like head bolts and the like i need to know everything about this as i want to do it with the help of my friend (mechanic)
Thanks Richie
Thanks Richie
Former Moderator
Re: D15z1 Head swap (richie_vei_uk)
I'd try to get the intake manifold along with the D16Z6 head if I were you.
Basically get the intake manifold, complete head with cam, new head gasket from Honda, new intake and exhaust manifold gaskets, valvecover gasket, cam seal, VTEC valve D ring seal with screen, and a distributor O-ring.
I think you might be able to keep the Z1 distributor, but I'm not 100% about that.
I also think that the VTEC-E valvecover itself will work on the Z6 head, but again double check to make sure.
I know the VTEC solenoid itself will work from the Z1 on the Z6.
Re: D15z1 Head swap (B18C5-EH2)
The z1 distributor will work on the z6 head, they are the same. Which timing belt should be used? VX or Z6? I have heard that the VX belt is not correct for the typical d15b mini me, but I don't know about the d15z1.
Risky Business
Re: D15z1 Head swap (powerofdreams8)
Read my SOHC VTEC mini-me writeup (also in my sig): https://honda-tech.com/zerothread?id=554053
You will need the timing belt from the Z6...prices, parts, performance gains from a Z6 head swap are all in my writeup...make sure you check it out!
civic, correction, d15z1, d15z1z6, distributor, fit, gasket, head, honda, mini, replacement, sale, swap, timing, z6
