GSR in a EG
Old Oct 29, 2006 | 04:18 PM
jdm_eg06's Avatar
Default GSR in a EG
Hey honda fans, I need some help here.
Swapping a OBD2 GSR into my bubble. I decided to keep my car obd1 however. Bought a obd1 p72 and started slapping the harness on. noticed that the distributor connector seems to be a bit different. i was wondering if i would be able to simply swap my d16z6 (obd1 SOHC VTEC engine) dizzy onto this engine? (i looks like it will fit)
any advice on this would be greatly appreciated. thx
Old Oct 29, 2006 | 04:50 PM
dc2vu's Avatar
no it wont work, if you dont have the plugs then just hardwire it across..
Old Oct 29, 2006 | 05:15 PM
H9Omega's Avatar
do not hack up your obd1 harness to use the obd2 distributor. sell that distributor and buy an obd1 vtec distributor or you can just use the z6 dizzy but you must cut off the leg to clear the VTEC solenoid.
Old Oct 29, 2006 | 05:42 PM
jdm_eg06's Avatar
Default Re: GSR in a EG (jdm_eg06)
so your saying my z6 dizzy will work with slight modifications. will i still be able to use at least 2 of the 3 bolts that hold the dizzy to the head.
Old Oct 29, 2006 | 07:02 PM
spooncivic1's Avatar
its simple
if you have the 98 motor, use the obd2 dizzy, alt., injectors, etc...basically keep it how it came
and use the 96-01 gsr obd2 harness, it will plug straight in with no modifications, all you need to do is run the obd1 p72, which you already have
hope that helps
Old Oct 29, 2006 | 07:05 PM
VtecnTurbo's Avatar
Default Re: (spooncivic1)
use the obd2 harness its easy. the only wire you will have to run is for your tach. its the negative wire off the dist to the shock tower on the driver side.
Old Oct 29, 2006 | 07:11 PM
Default Re: (VtecnTurbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecnTurbo &raquo;</TD></TR><TR><TD CLASS="quote">use the obd2 harness its easy. the only wire you will have to run is for your tach. its the negative wire off the dist to the shock tower on the driver side. </TD></TR></TABLE>
no you dont. its a straight plug and play just liek any other honda swap...trust me my b16a2 in my 95 ex swapped straight in with a obd2 gsr harness and mounts
Old Oct 29, 2006 | 07:37 PM
dc2vu's Avatar
i didnt realize he had an obd2 dizzy also...but anyways...its really not a hard conversion...pretty much all the wires are switched directly over if u plan on swapping plugs, even for injector wiring
Old Oct 29, 2006 | 08:25 PM
instrument's Avatar
pictures?
i have an obd2 b18 in my vx...i had to do no such change..
Old Oct 29, 2006 | 08:55 PM
dc2vu's Avatar
so do i...its just that he has obd1 parts...u probably used obd2 everything like i did
Old Oct 30, 2006 | 09:09 AM
dorifto_83's Avatar
my tach stopped working after swap, 00 gsr into 93 del sol, can you explain a little more in depth<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecnTurbo &raquo;</TD></TR><TR><TD CLASS="quote">use the obd2 harness its easy. the only wire you will have to run is for your tach. its the negative wire off the dist to the shock tower on the driver side. </TD></TR></TABLE>
jdmjin
Nov 26, 2017 08:59 PM
SleepyHatchZ6
Mar 12, 2009 06:48 PM
revlimitcrx
Apr 2, 2006 12:29 PM
flatblackhatch
Dec 17, 2005 03:10 PM
FritzInTN
Mar 8, 2004 11:39 PM
