del sol 5 lug conversion help (URGENT)
Old Oct 28, 2006 | 06:04 AM
SOLvtec's Avatar
Default del sol 5 lug conversion help (URGENT)
i recently did the itr conversion on my del sol
i bled all the lines and the pedal goes to the floor
now i think in the process of doing this the fluid leaked a little low in my master cylinder
i was told that it probably ripped one of the seals that are in there
anyway
i searched and nothing really helped me
there is minimal braking power
as i said before the pedal is going strait to the floor without resistance
thanks for the help in advance
Modified by SOLvtec at 8:35 AM 10/29/2006
Old Oct 28, 2006 | 06:44 AM
instrument's Avatar
did you bleed in the correct order?
was you del sol four wheel disc to begin with? if not did you change your proportioner?
is your del sol abs?
if not isn't the type r abs?
97ShLude's Avatar
Default Re: del sol 5 lug conversion help (SOLvtec)
I "think" that a '91 civic wagon master cylinder will bolt up to your booster and its a 15/16ths....
Old Oct 28, 2006 | 06:57 AM
SOLvtec's Avatar
Default Re: (instrument)
yeah, mine was 4 wheel disc
mine=non abs
type r=abs
Old Oct 28, 2006 | 12:03 PM
SOLvtec's Avatar
Default Re: (SOLvtec)
thanks for the info
i just went and got a stock si one
hopefully it will work
Old Oct 28, 2006 | 12:09 PM
faster Type R's Avatar
just wondering what e brake cables did you use?
Old Oct 29, 2006 | 04:27 AM
SOLvtec's Avatar
Default Re: (fastertyper)
used my stock ones
Old Oct 29, 2006 | 04:36 AM
SOLvtec's Avatar
-now i replaced the master cylinder (correctly bench bled it)
-checked the brake booster to make sure it is still good
-bled everything again again and again
Old Oct 29, 2006 | 07:19 AM
SOLvtec's Avatar
bump
need help real bad
Old Oct 29, 2006 | 05:35 PM
SOLvtec's Avatar
bump
Old Oct 29, 2006 | 06:39 PM
del_slow420's Avatar
make sure u have no leaks or else it wont bleed or hold properly. i just deleted the abs **** in my del sol and one of my lines leaked and now its all better
DelSol-B18
19
Apr 1, 2013 12:38 PM
310HPS2k
10
Mar 13, 2009 05:45 PM
courtney42
Dec 12, 2008 12:09 PM
itsmejto
Aug 7, 2008 03:10 PM
aemfreak
Dec 1, 2004 10:53 AM
