Rear Disc Brake Conversion on DEL SOL, help!
I bought complete GSR brakes all around for my del sol
I have only isntalled the fronts.
The rear came with their own e brake cables. Can I use those? or do i REALLY need the del sol SI cables? because those are hard to find.
Also Is the brake Booster swap required?
Re: Rear Disc Brake Conversion on DEL SOL, help!
I think you probably need the del Sol cables. There's a del Sol over here (Titusville) in a junkyard that looks like it might have the cables still on it. I don't remember if it was an Si though. You could call them up, it's at East Mims Auto Salvage. Ask them about a blue del sol. Don't ask them the model, they probably won't know... just ask if it has rear discs. Then they can get it up on the forklift for you when you pull the cables.
The brake booster is a must, otherwise the system will fail at some point, sooner than later. There's no sense in upgrading your brakes if your not gonna upgrade them right
Just went to the junk yard they had a del sol Si but someone had to cut the ebrake cable! they didnt even need it.
anyways I pulled the brake booster/ master brake cylinder and the Prop valve from the del sol Si.
Is that correct or did I needed the ones from the GSR??
Seagull Management
They need to come from a non ABS Integra.
all 3 brake booster/ master brake cylinder and the Prop valve needs to be from the GSR?
damn i just wasted $50
Seagull Management
You can always sell the prop valve (its for a small front discs and rear discs, good for doing a rear disc swap when not upgrading the front.
1 Post
actually your sol is non abs right? so it'd have to be from a non abs teggy or si
ps how is the setup in the front working for you? any camber issues or any other probelms?
gmcuajo1
06-22-2014 07:23 AM
424racer
10-07-2010 09:17 PM
