broken thermostat
Old Oct 27, 2006 | 06:44 PM
92b16hatch's Avatar
Default broken thermostat
sup guys, i replaced my thermostat about a yr ago, maybe less and it stopped reading the temp on day...any ideas on whats wrong and how to fix it?...please post any thoughts or suggestions!! thanks
Old Oct 27, 2006 | 06:49 PM
deadline's Avatar
there's a lil plug under dizzy check that out ...maybe u need to replace the sensor ?
Old Oct 27, 2006 | 06:52 PM
EG2Driver's Avatar
Default Re: (deadline)
Is the thermo OEM becuase if the it isn't , then its most likely the problem.
Are you getting heat from the heater? If not, thats another clue that it is your t-stat.
Old Oct 28, 2006 | 07:39 AM
92b16hatch's Avatar
yea, im getting heat fine...and i unplugged that sensorto the thermostat and same thing happened..doesnt read anything
Old Oct 29, 2006 | 07:25 AM
92b16hatch's Avatar
any ideas????pleasee post
Old Oct 29, 2006 | 08:10 AM
sammysnakes's Avatar
sounds like a bad coolant temp sensor.
Old Oct 29, 2006 | 07:55 PM
92b16hatch's Avatar
ok, so how do i check that?...where is it located so i can replace it?????????????
Modified by 92b16hatch at 3:54 PM 10/30/2006
Old Oct 31, 2006 | 04:03 PM
92b16hatch's Avatar
aight, well after 34 bucks i replaced that sensor and it's still not reading anything...any ideas guys?
Old Oct 31, 2006 | 06:33 PM
stock_honda_coupe's Avatar
Default Re: (92b16hatch)
something is wrong in the coolant temp sensor wiring or in the gauge its self
Old Nov 1, 2006 | 07:28 PM
92b16hatch's Avatar
i was thinkin about switching the wires up..but then i realized that it was working at 1 point just the way it was...it stopped suddenly...could it be a fuse??
Old Nov 2, 2006 | 04:27 AM
i'm not sure if there's a fuse, but i wouldn't switch the wires. i would check the wiring for damage & check the cluster like stock_honda_coupe said. swap clusters with a friend and see if it works. if it doesn't, it's either wire damage or possibly your ecu.
crx-newbie
Nov 1, 2009 04:40 PM
StupidWrench
Mar 17, 2005 07:22 PM
vtecaccord 1
Dec 7, 2004 05:59 AM
Del Souless
Jun 17, 2004 07:07 PM
DOHCarp
Sep 19, 2003 09:35 AM
