bypass the srs light with after market steering wheels..
u dont need to cut the wire nor pull the bulb, just disconnect the wire behind the cluster closest to the bulb, it should be yellow...thats what i did for my buddies car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkipMic2006 »</TD></TR><TR><TD CLASS="quote">if i cut the wire at the steering wheel will hte light still come on normal and then go off after start up ?</TD></TR></TABLE>
no, the light only goes off if the SRS system is working properly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkipMic2006 »</TD></TR><TR><TD CLASS="quote">no i mean will the light still go off everytime u start the car and then it goes away. not stay on like there something wrong with the air bag system....</TD></TR></TABLE>
if you use an aftermarket steering wheel there will be somethign wrong with teh air bag system...theres no drivers side airbag.
Well yah, I could do that... but I am actually a little concerned that my airbag system may not be working properly. I replaced my gauge cluster after I bought the car and the light was unplugged on the old cluster... so apparantly it's been on for a while.
