Metal shavings on transmission plug (searched)
Old Oct 26, 2006 | 04:01 PM
spoonracer84eg's Avatar
Default Metal shavings on transmission plug (searched)
I just changed my tranny fluid and the magnetic drain plug had metal shavings on it. I just recently had a new clutch and flywheel installed so im thinking its just the new clutch and its ok. Has anyone else had this problem.
Old Oct 26, 2006 | 04:03 PM
B16B_coupe's Avatar
HRD PKR
Default Re: Metal shavings on transmission plug (spoonracer84eg)
everytime i change the trany fluid on cars at my work there is some metal on it.. a little not a whole whole lot.. but some.. its all ok... thats what the plug is magnetic for
Old Oct 26, 2006 | 04:04 PM
Kinda figured its just the clutch wearing down. Anyone else?
Old Oct 26, 2006 | 04:05 PM
B16B_coupe's Avatar
HRD PKR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonracer84eg &raquo;</TD></TR><TR><TD CLASS="quote">Kinda figured its just the clutch wearing down. Anyone else?</TD></TR></TABLE>
yeah.. its fine believe mme.
Old Oct 26, 2006 | 04:18 PM
chingpo05's Avatar
no you are WRONG it is not the clutch wearing down. the clutch has nothing to do with metal shavings in your tranny. its natural to have metal on the drain plug but not much.
the cluch and flywheel is in between the tranny and motor having no contact with the interior of the tranny or motor
Old Oct 26, 2006 | 05:48 PM
Default Re: Metal shavings on transmission plug (chingpo05)
i understand that. u really dont have much of a point.
Old Oct 26, 2006 | 05:52 PM
Bense's Avatar
THINK about this one for a second here. Just think. Don't resort to other peoples answers for everything, use your brain.
When you fill your transmission with oil, do you pull your start off and just dump oil on your clutch? No.
What's inside a FWD transmission? Hmm.... Gears, bearings, synchros, synchro sleeves. differential....
Synchros are made of brass, brass does not stick to magnets.
What causes metal shavings. Hmm.
Old Oct 26, 2006 | 05:56 PM
ek_chris's Avatar
only the baulk rings are made out of brass.
Shavings are always normal, but not that much, also if they are abnormally large shavings that is not good. Most common shavings are the shavings from the reverse gears since it does have an idler gear that slides into place, it likes to grind a bit. How many K on the transmission?
Old Oct 26, 2006 | 06:42 PM
stock_honda_coupe's Avatar
Default Re: (ek_chris)
Its good unless theres a lot or they are big. A good way to tell if you have a large problem is to listen to your tranny, if it wines really loud then you might have a problem.
anotherwhitehatch
Transmission & Drivetrain
Nov 21, 2011 02:56 PM
lisajasmin
Jun 4, 2008 04:56 PM
miller
Apr 24, 2006 02:58 PM
Y2ksi
Apr 7, 2005 07:55 PM
monsterb18b
Nov 20, 2003 09:45 AM
