can I drive my car like this?(((((help))))))
Old May 5, 2002 | 09:16 PM
-=TWITCH=-'s Avatar
Default can I drive my car like this?(((((help))))))
sorry to spam but noone will answer
I adjusted my valves wrong and now they tap loud is it ok to drive it to school and then to my friends to get it fixed? see my other post please I need help
https://honda-tech.com/zerothread?id=179225
Old May 5, 2002 | 09:51 PM
-=TWITCH=-'s Avatar
Default Re: can I drive my car like this?(((((help)))))) (-=TWITCH=-)
help
Old May 5, 2002 | 09:59 PM
Malgerus's Avatar
Get it fixed before you drive it anywhere... those broken bolts make me shudder BTW you cannot adjust the valves right after you drive it, in case you didn't know..
Old May 6, 2002 | 05:33 AM
-=TWITCH=-'s Avatar
Default Re: can I drive my car like this?(((((help)))))) (89_Y_49)
The car was cool when we did the adjust! but I need to know how im going to get the other part of the boltout because its down in the block and I dont know If I can get to it because its the journal hole!
Old May 6, 2002 | 08:27 AM
Urban Business
Guest
Posts: n/a
bleh sounds like you fuct yo **** up replace those bolts asap. when pulling timing **** apart have to aline pully dot UP and cam gear UP and make sire the 2 horazontal lines are even w/ valve cover. this will ensure tdc. so you dropped a bolt in your motor? if your going to drive anywhere do not rev it at all. if your valves are smashing into pistons your going to have a ton of damage, new pistons and valves will most likely be needed. if you have to drive it drive it slow like a grandma
Old May 6, 2002 | 09:19 AM
-=TWITCH=-'s Avatar
Default Re: can I drive my car like this?(((((help)))))) (C5_ALLMOTOR)
OK I got my mom to drive me to school now I just to need to get my car to my friends house and pray to god I can get the bolts out to fix this! just to make sure with you guys there are two white dots on my game gear teeth and then there are two up arrows that say up witch do I use to make sure im TDC this could make a huge diffrence!
Old May 6, 2002 | 09:34 AM
badCRX's Avatar
New User
If its dropped in the holes, hopefully the pieces will make it down to the oil pan and not get stuck in between. I would suggest taking off the oil pan if you get a chance when you are done to look for them.
Old May 6, 2002 | 09:41 AM
-=TWITCH=-'s Avatar
Default Re: can I drive my car like this?(((((help)))))) (badCRX)
NO theres not a bolt that I droped down in the motor I just broke off 2 bolts that scrrew into the block I have one peice and the other peice is still in the block! I just need to make it to my friends house hopefully they will hold
Old May 6, 2002 | 10:05 AM
Urban Business
Guest
Posts: n/a
oh bleh i thought you had **** in your block =P up does UP and there:
should look like this:
UP
those lines are horizontal w/ valve cover, UP goes up
i cant get this to format properly
[Modified by TorteX, 7:08 PM 5/6/2002]
Old May 6, 2002 | 01:27 PM
JustChou's Avatar
oh man...you're going to have to use an extractor and those NEVER work right...good luck.
Old May 6, 2002 | 01:36 PM
xci_ed6's Avatar
Default Re: can I drive my car like this?(((((help)))))) (JustChou)
I would recomend doing it yourself. If your friend doesn't even know how to line up TDC I wouldn't trust him. When adjusting your valves the only bolts you need to remove completely are the ones that hold on the valve cover gasket.
-Dustin
Old May 6, 2002 | 01:39 PM
M-EJ1's Avatar
damn... just adjusted my valves yesterday and accidentally broke off one of the valve cover bolts on my SOHC. What a way to end a perfectly good day. Now I gotta go down and pay through my nose to get a new one from the honda dealer, then I gotta drill out the old bolt and find a metric tap/die set so I can re-thread the damn hole. All the while, making sure I get no metal shavings in my valves. UGH.
Old May 6, 2002 | 04:02 PM
89 CRX SI's Avatar
Default Re: can I drive my car like this?(((((help)))))) (matt-eg)
i can get it for 2.05 at my dealer cause i jsut got one. if ya need it give me a shout
Old May 6, 2002 | 04:46 PM
xci_ed6's Avatar
Default Re: can I drive my car like this?(((((help)))))) (89 CRX SI)
when drilling out or whatever to keep metal shavings out stab a oil soaked rag over the stud. It will perfectly suround the hole and the oil will prevent the metal shavings from falling onto surrounding parts. can use a heavier rease too.
-Dustin
Old May 6, 2002 | 04:49 PM
Cryptopsy's Avatar
Oh man! Sorry to say this, but man you are having some problems aren't you. I think you need to put down the wrench and decide wether or not you really should be doing your own engine work.
Anyways, I hope ya get things worked out for ya. Good luck.
Old May 6, 2002 | 05:45 PM
-=TWITCH=-'s Avatar
Default Re: can I drive my car like this?(((((help)))))) (SoulflyCRXsi)
I didnt do this it was my friend who thought he knew what he was doing.....ahhhhh and now I have to take it to a shop to get fixed but hell im learing alot! but learning it the hard way
Old May 7, 2002 | 01:14 PM
Cryptopsy's Avatar
Well, when it comes to cars, the only way to learn the best is the hard way. heh.
mkw1
May 28, 2008 09:35 AM
B18CR-X
Nov 28, 2005 09:31 PM
1.7na
May 31, 2004 07:12 PM
coldfiremx
Mar 9, 2003 04:01 PM
-=TWITCH=-
May 6, 2002 09:39 AM
