Idle surges with clutch pushed in?
Old Oct 25, 2006 | 07:03 PM
sol_93's Avatar
Default Idle surges with clutch pushed in?
i have a 93 sol with a jdm d15b swap, manual s20 tranny swap, and it just started doing this. When i start it and hold the clutch in the idle surges. has anybody ever had this happened?
Old Oct 25, 2006 | 07:08 PM
ST4TUS's Avatar
Default Re: Idle surges with clutch pushed in? (sol_93)
try cleaning your IAC Valve
Old Oct 25, 2006 | 07:27 PM
speedracer209's Avatar
vacuum leak or MAP sensor.
Old Oct 26, 2006 | 05:42 AM
sol_93's Avatar
Default Re: Idle surges with clutch pushed in? (speedracer209)
so do those three things have to deal with the clutch? its only with the clutch pressed in, when its depressed its fine.
Old Oct 26, 2006 | 01:52 PM
if only does it when your clutch is pushed in because there is no load on the engine hence nothing to stop it from surgeing up and down.
Old Oct 27, 2006 | 01:49 PM
sol_93's Avatar
cleaned the iacv, still doing it, checked for vacuum leaks and theres none of those. how would i test the map sensor?
Old Oct 27, 2006 | 05:59 PM
either find a buddy who will let you try his on yours or I think but don't quote me on this that autozone will test them. If no leaks and IAC is clean then its more then likely the MAP.
Old Oct 27, 2006 | 06:09 PM
f20bej1's Avatar
they are right its alway two major things iacv or leak in vacuum lines 9 out 10
Old Oct 28, 2006 | 01:42 PM
furiouscivic's Avatar
air bubbles in the cooling system cause this too!
Old Oct 28, 2006 | 02:47 PM
sol_93's Avatar
Default Re: Idle surges with clutch pushed in? (furiouscivic)
nope theres no air bubbles, i just did a coolant flush and checked that 1st thing.
Old Oct 28, 2006 | 03:22 PM
spoonracer84eg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sol_93 &raquo;</TD></TR><TR><TD CLASS="quote">nope theres no air bubbles, i just did a coolant flush and checked that 1st thing.</TD></TR></TABLE>
Yes but did you bleed your system
Old Oct 29, 2006 | 08:55 AM
sol_93's Avatar
Default Re: Idle surges with clutch pushed in? (spoonracer84eg)
of course! im not an idiot lol
Old Oct 29, 2006 | 09:16 AM
Syndacate's Avatar
Got a Q....is it ONLY when the clutch is in...or if you put it in neutral and let the clutch out does it still surge? Think it's an idling problem..which isn't just when your clutch is pushed in, it's whenever ur at idle..
Does the idle even out at any time? like after the car's warmed up or something?
Old Oct 29, 2006 | 09:26 AM
sol_93's Avatar
Default Re: (Syndacate)
its only when the clutch is pushed in. and i believe i found the problem....the dumbass that had it before me converted it to manual and didnt change the ecu to a manual ecu so its throwin a code for neutral position sensor.
Old Oct 29, 2006 | 09:31 AM
Syndacate's Avatar
Default Re: (sol_93)
Yeah, that would do it..
I was gonna say, all these bitches are like "IACV!!" or "AIR LEAK" etc. etc. but if it's ONLY when the clutch is in (and not when you're in neutral with the clutch out) then I highly doubt it's any of those things.
To tell you the truth though I didn't even know there was a neutral positioning sensor...I did a auto &gt; man conversion ...oh nvm...I used a man ECU right from the getko...blah...
Ya, well glad to see u got it working....
Old Oct 29, 2006 | 10:17 PM
sol_93's Avatar
yea im just waitin on my ecu to get here now. stupid bitch shoulda changed it in the first place lol.
Old Oct 30, 2006 | 09:10 PM
**** thats news to me about that
S1mpl3xity
Sep 15, 2011 09:28 PM
cloudconnected85
Sep 21, 2008 07:46 PM
thechamp657
Oct 12, 2007 02:23 AM
eluder33
Mar 1, 2005 10:47 AM
J-g-D-s-M-r
Sep 3, 2003 01:44 PM
