EG Rear Sway Bar?
Old Oct 25, 2006 | 05:26 PM
areem57's Avatar
Default EG Rear Sway Bar?
Does anyone kno if there are holes for the bolts on a 92 Civic CX for a Integra Rear Sway Bar? Holes for the brakets on the bar.
Old Oct 25, 2006 | 05:33 PM
Sleepy_Red_hatch's Avatar
Default Re: EG Rear Sway Bar? (areem57)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by areem57 &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone kno if there are holes for the bolts on a 92 Civic CX for a Integra Rear Sway Bar? Holes for the brakets on the bar.</TD></TR></TABLE>
the "C" beackets, yes. the endlinks, no.
Old Oct 25, 2006 | 06:33 PM
areem57's Avatar
Default Re: EG Rear Sway Bar? (Sleepy_Red_hatch)
I dont understand? There are holes on the chassis for the c brakets?
Old Oct 25, 2006 | 06:37 PM
whatsthatnoise's Avatar
swap the rear control arms with the integra ones you got the swaybar from.
Note: if you change bushings the acura bushings are larger in diameter than the honda ones. Other than that they swap over no problem. This is what i did on my coupe.
Old Oct 25, 2006 | 07:04 PM
areem57's Avatar
Default Re: EG Rear Sway Bar? (whatsthatnoise)
I have the integra control arms, im not talking about the end links im talking about the other brakets. If you still dont understand I have a picture.
Old Oct 25, 2006 | 07:52 PM
BlueIntegraBoy's Avatar
http://importnut.net/swaybar.htm
Old Oct 25, 2006 | 08:27 PM
eg9matt's Avatar
yes the holes are on the subframe but u have to put a nut on the inside of the subframe to hold the plates i used header nuts the work fine with the 12mm bolts that u have to use
Old Oct 26, 2006 | 05:24 PM
Default Re: (eg9matt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">http://importnut.net/swaybar.htm</TD></TR></TABLE> If you can't figure it out by viewing his link then i highly recommend you not work on your car
nomoshing
Dec 17, 2009 02:54 PM
Notorious_T
Dec 8, 2008 05:41 PM
918eg
Sep 4, 2008 02:05 PM
JayDM-hatch
Feb 18, 2008 11:05 AM
sccivichatch
14
Jun 10, 2005 05:28 PM
