Integra sway bar in civic???
I have a 94 integra and was wondering if I can swap the sway bar onto my eg?? I know I would have to use the integra lower controle arms but would the sway bar bushing brakets bolt up to the eg chasis?? Any help would be great..
Re: Integra sway bar in civic??? (JayDM-hatch)
You need to take the following from your integra to make it work on your hatch : Rear lower control arms, Sway bar brackets ( they are bolted to the subframe ) D brackets, bushings and the bar with endlinks. Take one of the bolts that bolted into the subframe on the integra and go to lowes/home depot and get longer bolts, washers, lock washers, and nuts.
I did this on my 92 CX hatch , the sub frame on the hatch has the holes but they aren't threaded like the integra sub frame is.
