? change miles
Old Oct 24, 2006 | 05:45 PM
civicguy1984's Avatar
Default ? change miles
hey i picked up a used set of gauges for my 97 civic hx, im wondering how to add miles to the cluster to make it right with the factory! Anybody know how?
Old Oct 24, 2006 | 05:52 PM
EG2Driver's Avatar
Default Re: ? change miles (civicguy1984)
get your local dealer to do it and certify it.
Old Oct 24, 2006 | 06:17 PM
bart2546's Avatar
Default Re: ? change miles (DeadEnd9009)
on the back, where the speedo cable would hook in there should be a small square or such that the cable end seats in. Find yourself a small flathead screwdriver bit that would fit in a power drill and the flathead part should be small enough to fit in the squared hole of the speedo. Put the bit in an airpowered sander or grinder, then insert the bit into the back of the speedo and go to town. You can use just a power drill but it will take a while. When I broke my speedo needle completely off of my old subaru when putting in indiglo gauges, I had to get one from the junkyard. My car had 97,xxx on it and the one I pulled had about 150,xxx. I had to spin it backwards with a drill, I quit after about 5 miles on the guage but going forward you should have no problem with just a few minutes.
Old Oct 24, 2006 | 06:48 PM
Sleepy_Red_hatch's Avatar
Default Re: ? change miles (bart2546)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bart2546 &raquo;</TD></TR><TR><TD CLASS="quote">on the back, where the speedo cable would hook in there should be a small square or such that the cable end seats in. Find yourself a small flathead screwdriver bit that would fit in a power drill and the flathead part should be small enough to fit in the squared hole of the speedo. Put the bit in an airpowered sander or grinder, then insert the bit into the back of the speedo and go to town. You can use just a power drill but it will take a while. When I broke my speedo needle completely off of my old subaru when putting in indiglo gauges, I had to get one from the junkyard. My car had 97,xxx on it and the one I pulled had about 150,xxx. I had to spin it backwards with a drill, I quit after about 5 miles on the guage but going forward you should have no problem with just a few minutes. </TD></TR></TABLE>
its too bad that since 1992 MOST hondas have had electronic VSS's instead of the old-fashioned cable operated cavemen-like technology
Old Oct 24, 2006 | 06:58 PM
bart2546's Avatar
Default Re: ? change miles (Sleepy_Red_hatch)
Well if that's the case then yea it wouldn't help him. I wasn't aware of what models have electronic VSS, just trying to give an idea in case it would help.
Old Oct 24, 2006 | 07:52 PM
EJgsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleepy_Red_hatch &raquo;</TD></TR><TR><TD CLASS="quote">
its too bad that since 1992 MOST hondas have had electronic VSS's instead of the old-fashioned cable operated cavemen-like technology</TD></TR></TABLE>
ahahahah thats funny. caveman.
OBD0
Old Oct 24, 2006 | 08:34 PM
Eran's Avatar
HT White Ops
Just pull the entire speedo section from your stock cluster. That's what I did for my CX when I got an EX cluster.
Old Oct 24, 2006 | 10:35 PM
ddd4114's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeadEnd9009 &raquo;</TD></TR><TR><TD CLASS="quote">get your local dealer to do it and certify it.</TD></TR></TABLE>
how much would that cost?
Old Oct 24, 2006 | 10:44 PM
Jimmy's Avatar
Global Moderator
Default Re: ? change miles (ddd4114)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ddd4114 &raquo;</TD></TR><TR><TD CLASS="quote">how much would that cost?</TD></TR></TABLE>
Probally ALOT or atleast dealerships around here bullshit.
Old Oct 25, 2006 | 06:10 AM
EG2Driver's Avatar
Default Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">Just pull the entire speedo section from your stock cluster. That's what I did for my CX when I got an EX cluster.</TD></TR></TABLE>
when i come to think of it, just do this if the speedo is the same size. Eran
Old Oct 25, 2006 | 06:42 AM
ekgsr's Avatar
Default Re: (DeadEnd9009)
I called down at my local dealership today to see how much for a civic cluster. . . estimated : $1,100 just for the parts
Old Oct 25, 2006 | 06:45 AM
ddd4114's Avatar
Default Re: (ekgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekgsr &raquo;</TD></TR><TR><TD CLASS="quote">I called down at my local dealership today to see how much for a civic cluster. . . estimated : $1,100 just for the parts </TD></TR></TABLE>
haha...
that's a crime...
Old Oct 25, 2006 | 06:47 AM
instructor74's Avatar
Default Re: (ekgsr)
call around or open a phone book there are shops around that do speedo calibrations. it shouldn't cost all that much to have it done and then it will be certified. Talk to your local mechanic or even the dealer they should be able to point you in the right direction
Old Oct 25, 2006 | 10:04 AM
i read your posting last night. and stared at that cluster for about an hour trying to figure out what you wrote!!! im glad someone posted that it wasnt right years! I am alittle slow when im tired!! HAHA
DraginTeg93
Dec 4, 2008 10:00 AM
Elbowpunk
Dec 23, 2005 02:10 PM
remstarasianboy
Oct 25, 2005 10:15 AM
coot_er
Oct 2, 2005 10:33 PM
uriba69
11
Mar 11, 2004 12:07 PM
