Big Vss Problem .. Help
Old Nov 28, 2008 | 08:14 PM
DraginTeg93's Avatar
Default Big Vss Problem .. Help
ok so i having a problem with my Vss , Speedometer and speedometer cable .. First my speedo cable went back so i didnt get one for a couple of days cuz it was on back order drove around my car and after 3 -4 miles the light would come on .. so i took my car apart got the new one put it in and now the light comes on right away .. the needle gos from 20 mph to 80 mhp . with the new cable .. ?? im lost .. so i take everything out of the car .. take the cluster and the cable put a drill on the end of it and it works fine all the way up 120mph. then i put the vss on and it works FINE . so i put everything back in the car and the speedometer needle wants to jump all around ... i drove it with the old cable broken for 3 days a code after 3-4 miles . new cable needle bonces around and light right away ...
Any helpp .. anyone have this problem .. its a 1993 integra ..
Old Nov 28, 2008 | 09:47 PM
Mfoehrkolb's Avatar
http://www.youtube.com/watch?v=8lIEGaWfi4Y
Look like that? Minus the ugly white faced gauges (removed).
that was just a horrible connection. I ended up buying a new connector and splicing it in. If the connector isn't making a true and secure connection it will jump around like so.
Old Nov 29, 2008 | 01:41 PM
yes that what it does .. but mines used a Cable .. any in put ??
Old Nov 29, 2008 | 03:20 PM
Ls92's Avatar
mines was saying I was doing 120 when I was doing 45.Turned out ,that the cable kept coming out of the vss just a little bit.
Old Nov 30, 2008 | 08:46 AM
i dont beleave thats my problem eather .. but how did u keep it from staying in cuz it already has the clip ..
help i cant even drive my car
Old Nov 30, 2008 | 04:34 PM
Ls92's Avatar
I had to take it out of the vss and put it back in a couple times because it kept happening(it wouldnt seat all the way either ,so that took a few tries),I ordered a new clip to hold it in the vss just incase it happens again.
Old Nov 30, 2008 | 05:35 PM
yeah i took mine out as it says in my first posting .. im Lost anyone ??
Old Dec 1, 2008 | 07:22 PM
bump
Old Dec 2, 2008 | 07:49 PM
anyone
Old Dec 4, 2008 | 10:00 AM
fix this problem thanks for the help
GPC91
Sep 17, 2012 01:11 PM
DraginTeg93
Transmission & Drivetrain
Dec 1, 2008 07:23 PM
saikouEF8
Mar 28, 2006 09:42 AM
PA MATT
Apr 6, 2004 07:40 PM
PhatHardy
Jan 6, 2003 08:01 AM
