thermostat stuck open, can i drive it without hurting it????
00 civic si turbo, i just installed a new rad. fan and noticed that my temp gauge was staying at cold, i need to drive it 30 miles before repalcing the thermostat, is it fine????
open, the car wont heat up to operating temperature. so with a bad thermostat i cant see if my new fan works. so its ok to drive if its open???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1baddcivicsi »</TD></TR><TR><TD CLASS="quote">open, the car wont heat up to operating temperature. so with a bad thermostat i cant see if my new fan works. so its ok to drive if its open???</TD></TR></TABLE>open, yes
Open is fine as others have stated, the only thing is that since your car will not reach the ideal operating temp, (yes, you can overcool a car) your gas milage will take a hit becuase the ECU thinks the engine is still trying to warm up.
my friend drove his car for 4.5 YEARS with stuck-open thermostat...
And the car is fine.... the only drawback is getting VTEC working on cold days cos when car finally warms up to an operating temperature, if you drive on the highway on low/mid range, the temperature GOES DOWN
And you can't use the heater in the cabin so you will probably catch a cold if you drive for a long time...
But 30 miles is nothing... just go for it, replace the t-stat and you're set
mortificationrock
Jun 23, 2008 02:48 PM
1baddcivicsi
Oct 24, 2006 04:29 PM
