Compression Test Results on 97ITR-296
After changing my Distributor Cap and Rotor yesterday, I decided to run a Compression test. Wanted to see how she is holding up.
Cylinder 1 - 200
Cylinder 2 - 200
Cylinder 3 - 210
Cylinder 4 - 200
Are thses reults normal. Motor has 94,000kms
Thank you to all you respond.
looks good
don't worry about if someone pops in and says the #s are low or anything like that...
each compression gauge will read differently
consistency is the key
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR »</TD></TR><TR><TD CLASS="quote">
consistency is the key</TD></TR></TABLE>
yes yes yes....
yes yes yes....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doostur »</TD></TR><TR><TD CLASS="quote">Mine were 225, 225, 224, 225 ... hrmmm that normal?</TD></TR></TABLE>
noooooo~~ it's off by 1 psi.. your motor's gonna blow up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR »</TD></TR><TR><TD CLASS="quote">consistency is the key</TD></TR></TABLE>
If only eveyone could live by this code of compression
mine are between 208-212...i did it cause i was worried about the engine using a little bit of oil. im going to change the pcv tomorrow and hope for the best...
I just ran mine yesterday...
Cylinder 1 - 124
Cylidner 2 - 245
Cylidner 3 - 12
Cylinder 4 - 227
Is this bad?
... HAHAHAHHA, gotcha.
Wish I could have seen the look on some of your faces, haha... Sorry, I'm easily amused.
Those numbers look good, like stated, consistancy is key.
Cylinder 1 - 124
Cylidner 2 - 245
Cylidner 3 - 12
Cylinder 4 - 227
Is this bad?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GO-FIGHT-KILL »</TD></TR><TR><TD CLASS="quote">I just ran mine yesterday...
Cylinder 1 - 124
Cylidner 2 - 245
Cylidner 3 - 12
Cylinder 4 - 227
Is this bad?
you laugh, someone i know decided to do a bolt on turbo kit with a generic map on an ECU, on a B16A2 civic.
after a week of use his compression numbers didn't look much different to those magical numbers you made up, just in a different order
Cylinder 1 - 124
Cylidner 2 - 245
Cylidner 3 - 12
Cylinder 4 - 227
Is this bad?
</TD></TR></TABLE>you laugh, someone i know decided to do a bolt on turbo kit with a generic map on an ECU, on a B16A2 civic.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GO-FIGHT-KILL »</TD></TR><TR><TD CLASS="quote">... Go buy the tool for $20... And do it yourself...</TD></TR></TABLE>
what is this tool called?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr1244 »</TD></TR><TR><TD CLASS="quote">"compression tester"</TD></TR></TABLE>
Haha, love the quotes... hahahahah
Like you're doing the "imagine the words in the air" hand motions... hahahahhaha
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by type_eg_r »</TD></TR><TR><TD CLASS="quote">
what is this tool called?</TD></TR></TABLE>
tool = "Opie"
hahaha - I haven't made fun of him in sooooo long. It must be nearing time to pay for Expo.
tool = "Opie"
