99 civic si cat-back exhuast suggestion
Old Oct 23, 2006 | 05:00 PM
vtecman's Avatar
Default 99 civic si cat-back exhuast suggestion
Hey guy I currently run a Apexi N1 cat-back on my 99 supercharged si and after 5 years its starting to fall apart does anybody have any suggestions on a different cat back or should I stick with the N1?
Thanks
Old Oct 23, 2006 | 05:17 PM
Bigmojoj27's Avatar
Default Re: 99 civic si cat-back exhuast suggestion (vtecman)
What part of the exhaust system is falling apart? I have the same exhaust, and the ends of my canister were rusting apart, so I just took it to a stainless-steel welder and welded a half-moon patch over it and everything was just fine. Saved a $$$ system is from the junk yard.
Old Oct 23, 2006 | 05:29 PM
vtecman's Avatar
Default Re: 99 civic si cat-back exhuast suggestion (Bigmojoj27)
It has a very small hole right were the muffler meets the pipe but then there is a 4 inch long hole about 6 inches from the muffler.
Old Oct 23, 2006 | 05:51 PM
si0385.'s Avatar
i guy i used to know had a apexi WS on a supercharged b16 and it sounded pretty tight... more for comfort and power than jsut power though its kind of a happy median
Old Oct 23, 2006 | 06:11 PM
Bigmojoj27's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecman &raquo;</TD></TR><TR><TD CLASS="quote">It has a very small hole right were the muffler meets the pipe but then there is a 4 inch long hole about 6 inches from the muffler. </TD></TR></TABLE>
Is it on the muffler or pipe? If it's on the back of the muffler, it sounds exaclty like what happend to mine. Just get a stainless steel welder to make a half-moon shaped patch and weld it on. $60-$80. Easy fix. Hardest part is finding someone to do it.
Old Oct 26, 2006 | 04:33 AM
vtecman's Avatar
bump bump!!
Old Oct 26, 2006 | 04:44 AM
blaze the chemi's Avatar
Just go to a good welder and they'll know how to fix it. Definitely save money. You live up north where the salt is?
Old Oct 28, 2006 | 07:56 AM
vtecman's Avatar
Default Re: 99 civic si cat-back exhuast suggestion (blaze the chemi)
OK but i if i don't fix it and get a new exhaust what would you guys suggest, because i want a change.
Old Oct 30, 2006 | 08:40 AM
vtecman's Avatar
ttt
Old Nov 23, 2006 | 06:26 AM
vtecman's Avatar
bump
Old Nov 23, 2006 | 07:06 AM
lowsiciv's Avatar
i live up here in saltsconsin and i also had an apexi n1 and after 2 damn years my **** rusted out. all i did was cut the can off and put an extension on it. sounded almost the same and i didnt have to buy a whole damn exhaust.
Old Nov 24, 2006 | 03:34 PM
vtecman's Avatar
Default Re: 99 civic si cat-back exhuast suggestion (lowsiciv)
does anybody know of a good exhaust thats looks and sounds good with 2 1/2 inch stainless steel piping??
Old Nov 24, 2006 | 11:09 PM
LYC's Avatar
LYC
T1R!!!!
Old Nov 25, 2006 | 04:35 AM
4thgenx42's Avatar
Look at 5zigen exhausts systems theyre good and quiet. Also look at some Bullet brand exhaust those are premium...
Old Nov 25, 2006 | 06:57 AM
Mr Hammond's Avatar
a/k/a Jomo
Thermal 3". All stainless.
Old Nov 25, 2006 | 02:52 PM
slkleltlclh's Avatar
Default Re: 99 civic si cat-back exhuast suggestion (Mr Hammond)
apexi worldsport exhausts sound and look beautiful. and have pretty sweet gains.
Old Nov 25, 2006 | 07:29 PM
madlion's Avatar
Default Re: 99 civic si cat-back exhuast suggestion (slkleltlclh)
custom 2.5"
piping get rid of the resonator and get a vibrant muffler
Old Nov 26, 2006 | 11:04 AM
vtecman's Avatar
Default Re: 99 civic si cat-back exhuast suggestion (madlion)
anybody else
Old Nov 26, 2006 | 12:05 PM
hks369's Avatar
hks hi-power
Old Nov 26, 2006 | 01:28 PM
Padawan's Avatar
Darth ModerVader
There are a relatively limited number of off-the-shelf exhausts that are SS with 2.5" piping. Most are either 2.25" or 3" (in the case of US manufacturers), or 60mm (Japanese manufacturers). Your N1 is 60mm, so if that is working for you now, you can select from the great number of bolt-on systems with that size piping. You can narrow your choices by deciding what style of muffler you prefer, the noise level you want, and how much you'd like to spend.
Old Nov 26, 2006 | 01:33 PM
Interlinker's Avatar
Default Re: 99 civic si cat-back exhuast suggestion (si0385.)
I have the Apexi WS2 and it sounds awesome!!! But I am not boosted. If you want the loud sound, go with the N1... if you want drivability, go with the WS2. But I can notice a slight difference at redline with the WS2 exhaust... but I have a better E.T. when I put it on though. Straight through exhausts like the N1 helps get rid of exhaust gases faster, especially on boosted cars. The slight bit more exhaust pressure is ideal for N/A cars and a minute difference on the top end. Straight throughs sacrifice gas mileage too.
beat_nut
23
Nov 28, 2004 08:03 PM
GreenEX
May 20, 2004 07:00 PM
OEMaccord96
Dec 8, 2003 03:52 PM
zseeanz
10
Oct 19, 2002 11:14 AM
