Nipple in PCV, what connects to it?
Old Oct 23, 2006 | 04:38 PM
bmw626's Avatar
Default Nipple in PCV, what connects to it?
i dont know what connects to it
btw, i haven't been running my car like this, i just swapped a boosted z6 in and and doing final prep work before i start it and noticed it earlier
Old Oct 23, 2006 | 05:11 PM
bmw626's Avatar
Default Re: Nipple in PCV, what connects to it? (bmw626)
bump
Old Oct 23, 2006 | 05:24 PM
NJcoupe's Avatar
Its for the IACV; it's coolant.
Old Oct 23, 2006 | 05:26 PM
t0p_sh0tta's Avatar
Default Re: Nipple in PCV, what connects to it? (dxcoupe.)
Don't start the car without hooking that up. Coolant will spray EVERYWHERE.
Luserkid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dxcoupe. &raquo;</TD></TR><TR><TD CLASS="quote">Its for the IACV; it's coolant.</TD></TR></TABLE>
Yep, that looks like its connected to the water tube. Your PCV is under number 3 and 4 runners of the intake manifold.
Old Oct 23, 2006 | 05:30 PM
bmw626's Avatar
Default Re: Nipple in PCV, what connects to it? (Luserkid)
do i connect the driver side or passenger side nipples of the iacv to that one?
Old Oct 23, 2006 | 05:31 PM
Luserkid's Avatar
Driver, then the pass side one connects to the FITV under the throttle body (provided you have one) or into the intake manifold nipple.
Old Oct 23, 2006 | 05:34 PM
bmw626's Avatar
alright, i will check it out in the morning and see whats left cuz i know when i swapped the motor in i had both tubes from the IACV connected to something. thanks
Old Oct 24, 2006 | 12:20 PM
bmw626's Avatar
ok, i got that one line fixed, now i have this one thats not hooked up (i have a piece of line there cuz i got pissed and cut it cuz i couldn't get it off). so now heres the new question, what hooks into this line?
Modified by bmw626 at 4:55 PM 10/24/2006
Old Oct 24, 2006 | 12:23 PM
bmw626's Avatar
btw, if you cant tell, its the one thats on the backside of the thermostat housing
Old Oct 24, 2006 | 12:33 PM
young noob's Avatar
is that connected the LARGE coolant passage thats connected to the intake manifold...i can't quite tell, but if it is, then that connects to the other nipple on the bottom of the throttle body
bmw626's Avatar
i am looking at this and it looks like its showing that the driver side iacv tube goes to where that nipple is in the pic i just took today, so if thats the case it was right to begin with but then where would that other nipple go (first pic)
Old Oct 24, 2006 | 12:52 PM
young noob's Avatar
thats different than my d-series...a d16y7, i have the iacv on the throttle body, but what im confused with is it shows the nipple you first posted about below the tb on the top-left of this diagram, but it doesn't show what it connects to, so look up where you found this diagram for that answer....and also, you have coolant running into the throttle body from the iacv, there has to be a cooland return line....my guess, and like it is on my y7, is there is another nipple right next to the one on the underside of the throttle body, and that is what connects to the other nipple on the long coolant stem that is with the labeld diagram "radiator lower hose"
Old Oct 24, 2006 | 01:50 PM
bmw626's Avatar
Default Re: Nipple in PCV, what connects to it? (young noob)
idk, what if i just do it how the diagram says, then just cap off that one nipple in the first pic? can i technically break anything? knowing my luck it will f up my idle or something
Old Oct 24, 2006 | 03:00 PM
young noob's Avatar
look on the bottom of your throttle body and see if there is another nipple that doesn't have anything on it
Old Oct 24, 2006 | 05:18 PM
bmw626's Avatar
you mean the FITV? yea, there is a hose coming out the back of it, one is going to the IACV i believe, i will have to check in the morning. and the other end of the FITV goes to a nipple connection in the head
Old Oct 26, 2006 | 01:53 PM
bmw626's Avatar
can i cap that connection off or not? anyone?
Old Oct 26, 2006 | 05:28 PM
bmw626's Avatar
oh well i capped it off
Oxadiba
Aug 9, 2015 04:56 AM
90blkteg
May 6, 2008 12:20 PM
TrueUntilDeath.com
Jan 25, 2008 03:38 PM
CRX_1.8T
Nov 29, 2005 07:47 PM
DC2LsVtec
Jun 23, 2003 11:52 AM
