oil and camgear???
Old Oct 23, 2006 | 04:17 AM
hbsir888's Avatar
Default oil and camgear???
i got a 92 hatch w/b16a, ctr camshafts, adjustable camgears, i.h.e. my question is i set the camgears at +1 intake, -1 exhaust, is this right? and i been use regular oil, someone told me synthetic oil will make my car run faster, is this ture? my best time on track was 15.2
Old Oct 23, 2006 | 04:39 AM
Eran's Avatar
HT White Ops
Anyone who told you synthetic will make your car run faster is a bald-faced liar. Synthetic simply provides more protection for your engine, but is not necessarily the best thing ever. What oil you use comes down to preference. Synthetic just costs more.
As far as your timing, put on a timing light and see if your timing is off, and if it is, put them back to 0.
Old Oct 23, 2006 | 07:33 AM
EK45VTi's Avatar
Default Re: (Eran)
BWAHAHAHAHAHA
Yeah, if you run fully synth in your engine, it will add more than 30WHP...
Then, if you buy the oil that has RACING (or just R) stamp on it, it will add aditional 20WHP...
And if you change it every 1000 miles like you should, you will gain additional 50WHP...
So, here's the formula:
- get some BADAZZZ REISING OIL and it must have at least red "R" stamped
- do not buy oil below 20$ a quart
- change it every 1000 miles
and you will have extra 100WHP...
No turbo or SC will give you that much instant power
Now for real...
Oil has nothing to do with how fast your car goes...
If you have money, go FULL SYNTH
if you have no money, go SEMI SYNTH
That simple...
Everything you need to worry about is to CHANGE IT REGULARLY (3000-5000 miles depending on driving conditions)
And don't forget to change the filter aswell
Old Oct 23, 2006 | 01:25 PM
hbsir888's Avatar
any idea for the camgears??
Old Oct 23, 2006 | 01:53 PM
EG2Driver's Avatar
Default Re: (hbsir888)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hbsir888 &raquo;</TD></TR><TR><TD CLASS="quote">any idea for the camgears??</TD></TR></TABLE>
like it was said, check your timing with a light.
Old Oct 23, 2006 | 02:17 PM
ten_second_crx's Avatar
Default Re: (DeadEnd9009)
Maybe my brain is not working right, but what affect would adjusting the cam gears (and thus, cam timing) by 1 degree have on ignition timing??
Old Oct 23, 2006 | 03:43 PM
EG2Driver's Avatar
Default Re: (ten_second_crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ten_second_crx &raquo;</TD></TR><TR><TD CLASS="quote">Maybe my brain is not working right, but what affect would adjusting the cam gears (and thus, cam timing) by 1 degree have on ignition timing??</TD></TR></TABLE>
the valves will open sooner
Old Oct 23, 2006 | 04:18 PM
Yeah, I get that. But how would checking the timing with a light have anything to do with where his cam gears are set?? I timing light checks ignition timing and cam gears adjust cam timing. I don't see the correlation that you are refering to.
newyawkballa
Honda Civic (2001 - 2005)
11
Feb 15, 2010 08:00 PM
SiYouLater
Acura TSX
Jul 27, 2007 02:36 PM
wangutang
Mar 8, 2006 07:10 AM
VINtegra90
Apr 18, 2005 03:00 PM
imadigitalgod
Feb 28, 2005 09:35 AM
