Loud Noise at Start Up
Old Oct 22, 2006 | 11:40 PM
ballerchild's Avatar
Default Loud Noise at Start Up
This just started happening to me yesterday. When I start my car, a LOUD clunking noise comes from the tranny and then it starts right up. I drove it around the block and the motor, tranny, and clutch seemed normal. Any input you guys can give me on what the noise might be and what I should check for would be greatly appreciated.
Old Oct 23, 2006 | 12:57 AM
keep this up top!
Old Oct 23, 2006 | 01:51 AM
bart2546's Avatar
Default Re: (ballerchild)
Possibly low on tranny fluid until it warms up and gets circulated? Bump for possible better ideas.
Old Oct 23, 2006 | 06:32 AM
eg-owns you's Avatar
could be that or your clutch is loose possible flywheel being loose who knows i say drain the trans put new oil in and see if that stops it if it doesnt then something eather in the trans or clutch and flywheel
Old Oct 23, 2006 | 09:36 AM
I'm about to change the tranny fluid later today.. any other suggestions?
Old Oct 23, 2006 | 09:39 AM
Archidictus's Avatar
Unceasing Measure
The starter bendix is probably jamming half-way out of the flywheel and causing a collision that jars it free. It's not an uncommon issue If your starter hasn't had problems in the past, it might be going out. I point to that as the most likely culprit. If you get a new one and the problem persists, a.) I'll be surprised and b.) you can just take it back and tell them it was the wrong one.
Good luck.
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ballerchild &raquo;</TD></TR><TR><TD CLASS="quote">I'm about to change the tranny fluid later today.. any other suggestions?</TD></TR></TABLE>
I wouldn't bother, as no amount (or lack thereof) of fluid in the transmission would cause clunking noises. Whining and grinding perhaps, but not clunking.
Old Oct 23, 2006 | 09:43 AM
Default Re: (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">The starter bendix is probably jamming half-way out of the flywheel and causing a collision that jars it free. It's not an uncommon issue If your starter hasn't had problems in the past, it might be going out. I point to that as the most likely culprit. If you get a new one and the problem persists, a.) I'll be surprised and b.) you can just take it back and tell them it was the wrong one.
Good luck.</TD></TR></TABLE>
Yea, i've had problems in the past with my starter, but a tap with my trusty screwdriver always worked wonders for me. I guess i'll be heading to the marketplace for a new starter. Thanks
jbpnoman
Feb 25, 2012 03:45 PM
PaJeeZy
May 6, 2010 03:42 PM
91EF919
Dec 8, 2008 06:10 PM
Ayeso
Oct 3, 2004 06:22 PM
goforbroke
Dec 15, 2002 02:48 PM
