block/head combo but what tranny?
Old Oct 22, 2006 | 06:13 PM
SLO Sol's Avatar
Default block/head combo but what tranny?
looking a B16 block off here and then a C1 head simple going to build both and hopefully install in the spring all motor civic. what tranny is going to be best for the setup. and for those of you that have done this what is your HP and Torque?
Old Oct 22, 2006 | 06:17 PM
92'si's Avatar
Default Re: block/head combo but what tranny? (D-money 92si)
si tranny for acceleration. only question is why the si block? why not a gsr, ls, b20? just question not flaming haha. i just think youll get way more power out of one of those blocks compared to a b16 block.
Old Oct 22, 2006 | 06:19 PM
-JSpecEk*9-'s Avatar
Default Re: block/head combo but what tranny? (92'si)
why are you using a gsr head? us a b16 head
Old Oct 22, 2006 | 06:22 PM
SLO Sol's Avatar
Default Re: block/head combo but what tranny? (JDMEK-9)
i was told if i have a built si block with a GSR head i will have more power than any individually
Old Oct 22, 2006 | 06:28 PM
92'si's Avatar
i really think its the other way around buds but yah use an s1 tranny and b16 head + b18c1 black = poor mans type r
Old Oct 22, 2006 | 06:33 PM
cambopheonix56's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92’si &raquo;</TD></TR><TR><TD CLASS="quote">i really think its the other way around buds but yah use an s1 tranny and b16 head + b18c1 black = poor mans type r</TD></TR></TABLE>
Right and since you are building the block all motor, you will want to rev high which means the b16 head will be more efficent.
Old Oct 22, 2006 | 06:36 PM
SLO Sol's Avatar
Default Re: block/head combo but what tranny? (cambopheonix56)
since there is a diffrence in size shouldnt the compression be higher
Old Oct 22, 2006 | 06:43 PM
kevmugen's Avatar
B16 tranny
Old Oct 22, 2006 | 06:47 PM
SkoundrelUSA's Avatar
cute little bastard
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-money 92si &raquo;</TD></TR><TR><TD CLASS="quote">since there is a diffrence in size shouldnt the compression be higher</TD></TR></TABLE>
The combustion chamber or w/e is smaller in the GSR head so it creates more compression. And don't listen to all the B16 head flows better and whatnot. Its not that much of a difference.
As for tranny: ITR or B16 (Y21, S4C)
Old Oct 22, 2006 | 07:13 PM
SLO Sol's Avatar
Default Re: block/head combo but what tranny? (SkoundrelUSA)
so the combo isnt a good idea or what?
Old Oct 22, 2006 | 07:15 PM
92'si's Avatar
no a combo is fine, just do you want all motor do you want turbo, are you trying to be on a budget?
Old Oct 22, 2006 | 07:17 PM
SLO Sol's Avatar
all motor and NO budget i have a running car i would like the new motor in by august but i can wait...
Old Oct 22, 2006 | 07:20 PM
Eran's Avatar
HT White Ops
It'd be probably cheaper and more efficent to do a b18b/b20b block and a b16 head, and then a b16 tranny with LS 5th gear.
Wewt.
Old Oct 22, 2006 | 07:22 PM
cute little bastard
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-money 92si &raquo;</TD></TR><TR><TD CLASS="quote">so the combo isnt a good idea or what?</TD></TR></TABLE>
No its fine. Just letting you know some info. As for staying N/A, will you be sticking with the 1.6?
Old Oct 22, 2006 | 07:25 PM
SLO Sol's Avatar
yes... that is the plan i am starting to research now as i found a block on here tonight
Old Oct 22, 2006 | 07:27 PM
92'si's Avatar
all motor no budget, woot woot go for k20 haha j/k. my buddy has a b20 vtec (b16 head, b20 block, b16 pistons) and got 182 whp with intake and exhaust. so combos are good buds.
Old Oct 22, 2006 | 07:30 PM
SLO Sol's Avatar
yeah i wanna build the block and head so i can beat or atleast keep up with some N/A guys
Old Oct 23, 2006 | 11:54 AM
sauceja's Avatar
No budget.
I would recommend the b18c block with choice of pistons, better rods. B16 head ported polished with minimum type r cams upgraded valvetrain.
I have a lsd Y21 and love it but I also agree with Eran as I will be in the market for an LS 5th gear. 3700 rpm's at 70 mph is not that fun after a while.
Good luck with your build and I recommend the b18c for simple fact of better rod/stroke ratio and vtec oiling is already routed. That is why I like them over the ls b18.
Otherwise I have a B16A block I would part out with as well.
rafig2001
Sep 20, 2010 12:05 PM
hondachris1994
Sep 6, 2006 06:23 PM
Elbowpunk
Nov 9, 2005 08:00 PM
HondaEconoBox
26
Oct 31, 2005 01:05 PM
Mr si99
12
Apr 26, 2005 08:08 PM
