Driving around with ECU throwing TPS sensor code?
Old Oct 21, 2006 | 04:43 PM
shabam's Avatar
Default Driving around with ECU throwing TPS sensor code?
I was just wondering if it is harmful to drive around with this code. The car seems to run fine; only on the initial start up the idle drops and almost dies and it comes back up, but after that idle holds fine. would this code cause me to run richer than normal?
Old Oct 22, 2006 | 08:10 AM
shabam's Avatar
Default Re: Driving around with ECU throwing TPS sensor code? (shabam)
bummp
Old Oct 22, 2006 | 11:34 AM
shabam's Avatar
bump
Old Oct 23, 2006 | 07:12 AM
candy eg's Avatar
From: The Real O.C. Oakland Chinatown, California, USA
Old Oct 23, 2006 | 08:31 AM
EFn JP's Avatar
Default Re: Driving around with ECU throwing TPS sensor code? (candy eg)
well i would say change it, tps sensors are not to much from a junkyard, i think any sensor not working is bad for the engine, IMO, figured honda built those sensors for a reason. seems logical that it could run richer or leaner if it can't read throttle right but then you have your map sensor trying to read pressure, so overall i would say fix it, a throttle body is 4 bolts and a tps is 2 screw shouldn't be to tuff gl
danekmeier
Jan 16, 2010 07:59 AM
shabam
Oct 23, 2006 07:14 AM
skiracer8148
Aug 2, 2006 03:26 AM
91 POS
Oct 10, 2003 03:17 PM
