Dynoed my Turbo D
Old Oct 21, 2006 | 03:31 PM
Boilermaker1's Avatar
Default Dynoed my Turbo D
Nothing really special, but I'm pretty happy... 6.2PSI, rises to 6.7 around the same time as the crossover
D17A2, stock bottom end and head
K series (310cc) injectors
HKS cast iron log, jethotted
Garrett GT28R (2854R)
22x5x3 vertical flow IC
2" from turbo to IC, 2.25 IC to TB
Porsche DV, recirc'ed
2.25" DP w/ 1.5" Divorced WG port
GT28RS 7 psi WG actuator
NGK BCPR7ES plugs
Tuned on E-manage (all there is besides ems)
Excuse my complete mess... I havent really had a chance to clean it up yet.
We tried to smooth out VTEC a little more, but the ECU was fighting with it and that was about as low as it would go without causing problems.
Old Oct 21, 2006 | 04:10 PM
drewzilla's Avatar
Default Re: Dynoed my Turbo D (Boilermaker1)
Cool little setup ya got there. That boost guage is sweet.
Old Oct 21, 2006 | 04:22 PM
redzcstandardhatch's Avatar
something different
nice man, not bad at all! lot more power than a stock engine... hows the spool.
Old Oct 21, 2006 | 05:00 PM
93supercoupe's Avatar
Default Re: (redzcstandardhatch)
WTF is that dip in the first graph, i hope its just the pick up or some ****.
Old Oct 21, 2006 | 05:23 PM
HiProfile's Avatar
Default Re: (93supercoupe)
I think its called EPA crawling up people's asses to get super-duper-ultra-low emissions ratings. The cam must be choking the engine like a drunken Sprewell, along with the intake not helping much. The numbers aren't that bad with that in mind, along with the tiny 2.25" dp. Even a small-radius 3" dp made from pie cuts would flow better.
Honestly I'd love so see a graph with that motor bolted to a 57trim doing 15psi. You'd go from 125tq to 275tq from 5500 to 5900rpm.
Old Oct 21, 2006 | 06:34 PM
turnsignalandy's Avatar
Default Re: (HiProfile)
how much money did u spend on the turbo setup total?
Old Oct 21, 2006 | 08:33 PM
locash's Avatar
Lower your VTEC switchover point.
Old Oct 21, 2006 | 08:40 PM
Attaus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">We tried to smooth out VTEC a little more, but the ECU was fighting with it and that was about as low as it would go without causing problems.</TD></TR></TABLE>
Read!
Old Oct 21, 2006 | 08:44 PM
sohc_vtec 2NR's Avatar
nice!! turbo D 17 in the house
claysno
Mid-Atlantic (Sales)
Apr 20, 2011 01:56 PM
94snatchback
Aug 1, 2010 09:17 AM
94snatchback
Aug 1, 2010 01:13 AM
dturbo
Sep 9, 2005 02:57 PM
19sec beast
Mar 20, 2005 06:50 AM
