EK D15B 3-Stage Vtec...
Old Oct 21, 2006 | 11:41 AM
HondaPride85's Avatar
Default JDM D15B 3-Stage Vtec with D16Y8 wire harness
I just put a EK D15B 3 stage vtec in my '96 EX Coupe. While I was hooking up the wire harness off the D16Y8 I noticed 2 or 3 sensor plugs were left open on it. The Vtec solenoid has 2 spools instead of 1, giving me a 2 wire plug that doesn't match the harness. What do I with the extras?! I connected the 2 Vtec solenoid wires to the single wire on the harness. Aren't they suppose to share the rpm signal anyways? Thanks for the help.
Modified by HondaPride85 at 12:54 PM 10/21/2006
Modified by HondaPride85 at 1:02 PM 10/21/2006
Old Oct 21, 2006 | 12:18 PM
Eran's Avatar
HT White Ops
No, they're not supposed to share the same RPM signal.
3-Stage VTEC works in this manner:
Below X RPMs:
Pin 1 and Pin 2 are out, both lobes spin freely, each cylinder runs on 3 valves. Economy Profile.
Above X RPMs:
Pin 1 is in, Lobe 1 is connected, Lobe 2 spins freely. Each cylinder runs on all 4 valves. Standard Profile.
Above Y RPMs:
Pin 2 is in, Lobe 2 is connected, Lobe 1 spins freely. Each cylinder runs on 4 valves. Lift and durration is increased. Power Profile.
Old Oct 21, 2006 | 12:48 PM
Default Re: (Eran)
Well, then what do I do with the extra (pink/red) wire that my harness lacks a connector for?
Old Apr 15, 2011 | 10:10 AM
Jestin25's Avatar
Default Re: EK D15B 3-Stage Vtec...
i want this same motor did u fix it
Old Apr 15, 2011 | 10:20 AM
vartok's Avatar
wow, gratz on pulling up a 4 1/2 year old thread... judging by the post numbers, they arent around anymore....
fyi, there are wireing diagrams on how to wire up the 2 spools to the ecu... GOOGLE
Old Apr 15, 2011 | 10:21 AM
grumblemarc's Avatar
The Grumpiest
You already have your own 3-stage VTEC thread going. Don't know what possessed you to bump this 5 year old one.
Jestin25's Avatar
LOL BUT I DID AND I CHOULDNT FIND ANYTHIN DO I NEED A NEW ECU
Old Apr 15, 2011 | 10:27 AM
vartok's Avatar
start your own thread with all the info about your swap and any other info you have and let this thread return to the dead
Old Apr 15, 2011 | 10:29 AM
The Grumpiest
He already has one.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/has-anyone-ever-donw-3-stage-vtec-swap-upgradesc-something-no-outcome-2921478/
Doesn't seem to be able to find anything on his own.
ahkbird
Aug 25, 2012 07:59 AM
allsho
Jun 14, 2007 12:06 PM
projecthonda
Feb 23, 2007 06:48 PM
GreddyCivic7
Feb 10, 2007 03:35 PM
sammydigital
Jun 9, 2006 05:31 PM
