Ignition problem
Old Oct 20, 2006 | 06:48 PM
BoltonGSR's Avatar
Default Ignition problem
Im not sure what its called exactly but where you put the key to start the car. Ignition switch i think? Any way i have a 92 legend and its really hard to take the key out. I have to wiggle the hell out of it. How easy is this to fix? How much?
Old Oct 21, 2006 | 06:48 AM
BoltonGSR's Avatar
Default Re: Ignition problem (BoltonGSR)
bump
Old Nov 1, 2006 | 08:38 AM
BoltonGSR's Avatar
bump, it says in alldata to disable the security?
Old Nov 1, 2006 | 03:57 PM
honda_power69's Avatar
I doubt this is something that is "repairable"...probably going to have to replace it. The cause of this is a heavy keychain, notice that if you take ur honda/acura to the dealer for service and you have a big-*** keychain when you pick the car back up the key will be in the ignition and they'll have ur keychain in the car disconnected from it.
I would just check pricing on a new unit.
Old Nov 1, 2006 | 06:21 PM
BoltonGSR's Avatar
Default Re: (honda_power69)
Thanks for info, but what im wandering is how do i disable the security system and ensure my radio is safe if i have to disconnect the battery?
Old Nov 2, 2006 | 07:06 AM
disconecting the battery will disable security. I'm not quite sure of your question the way its worded, but all you need for your radio (to ensure it will work when you reconnect the battery) is the security code. You can find this in the owner's manual (if you still have it)...if not its a little more of a bitch to get.
You'll need to pull the radio from the dash and get the Serial # & Model # off the back, they should be on a sticker. Once you have them written down, try calling one of the two dealerships below (I did some searching and both of these service departments are really good about giving out unlock codes without hassling you):
Elk Grove Acura:
(916)-392-1400
Poway Honda:
(858)-486-4300 (ask for Stephanie in Parts & Service)
This is the ONLY way to retrieve the unlock code unless its in your manual, hope this info has helped.
Old Nov 2, 2006 | 08:04 AM
BoltonGSR's Avatar
Thx for the info. Yes i still have that code. So when you reconnect the battery the radio will just say enter code?
Old Nov 6, 2006 | 02:06 AM
Default Re: (BoltonGSR)
Sure will, easy as cake. I didn't realize you already had the security code, but thats all you'll need...once reconnected the LED panel on the radio will say something to the extent of "CODE", then just punch in that number you have and its done.
Hope it all works out for ya.
-Jon
Old Nov 6, 2006 | 08:24 AM
BoltonGSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda_power69 &raquo;</TD></TR><TR><TD CLASS="quote">Sure will, easy as cake. I didn't realize you already had the security code, but thats all you'll need...once reconnected the LED panel on the radio will say something to the extent of "CODE", then just punch in that number you have and its done.
-Jon</TD></TR></TABLE> thanks
Schultzie
Honda Civic (2001 - 2005)
Dec 26, 2012 09:31 PM
Tx92AccordExD
Jul 22, 2003 03:52 PM
GroundZer0 336
Apr 10, 2003 07:52 AM
