Solid CEL, new ecu, SOLID CEL (srchd)
Old Oct 20, 2006 | 01:18 PM
Coltmorris's Avatar
Default Solid CEL, new ecu, SOLID CEL (srchd)
so its a d16a obd-1 --i had a solid cel forever and was not running a 4-wire o2 even though my car was wired for one. I finally put the sensor in and it wasnt getting any voltage--so i figured it was an ecu problem. I put in a nice new P28 and its still the same, solid cel and no voltage to the o2 sensor. My car runs and hits Vtec, although the idle is very rouch indeed--guys I suck at wiring what can I do to diag this problem?
Old Oct 20, 2006 | 03:27 PM
Chiovnidca's Avatar
Default Re: Solid CEL, new ecu, SOLID CEL (Coltmorris)
What trouble code does it have stored? Have you checked the wiring to the o2 sensor?
Old Oct 20, 2006 | 08:34 PM
Coltmorris's Avatar
Default Re: Solid CEL, new ecu, SOLID CEL (Chiovnidca)
well the wiring harness splices straight into the ecu--and i dont know what you mean by trouble code...ive tried jumpering the ecu and it still does not flash
Old Oct 21, 2006 | 04:14 AM
Sikocivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Coltmorris &raquo;</TD></TR><TR><TD CLASS="quote">well the wiring harness splices straight into the ecu--and i dont know what you mean by trouble code...ive tried jumpering the ecu and it still does not flash</TD></TR></TABLE>
You mean you cut the harness OBD0 and spliced in the OBD1 ECU plugs???
Why didn't you just use a jumper harness???
Old Oct 21, 2006 | 05:39 AM
Coltmorris's Avatar
Default Re: Solid CEL, new ecu, SOLID CEL (Sikocivic)
Well wait no--firstly I didnt do this odb1 conversion this is why im sorta cloudy. It has a jumper harness i think its the rywire one its the ornage brown grey and purple one..i followed that harness and it goes straight into one of the ecu plugs. Its def a 4-wire o2 harness because i asked about that before
Old Oct 22, 2006 | 07:11 AM
Coltmorris's Avatar
well new news...I AM getting voltage from the harness--but still have a solid cel...anyone know which wire goes to what on the harness and the o2 sensor?? i forget!
4g4dcruisin
Feb 14, 2010 07:23 AM
gettin it
Apr 28, 2007 08:13 AM
Oakmanx
Jan 31, 2006 05:12 AM
mhgleitz
Nov 6, 2003 08:43 AM
splitime
Sep 28, 2003 11:38 AM
