tb question...58mm vs. 62mm?
Old Oct 19, 2006 | 09:19 PM
the.hamburglar's Avatar
Default tb question...58mm vs. 62mm?
alright i dont really know how much of a difference this will make but i have an turbo ls vtec with itr cams and gsr pistons. 10:1 compression ratio, i guess a poor mans gsr. anyways,. i have a b16 tb on right now and i was thinking that i might see a noticable difference since i have the cams and 2.5" ic piping. now should i upgrade to a larger tb now or what would be the optimum size? 58mm seems kinda small. i have a gsr 60mm tb but the throttle rotor is all upside down...can i somehow switch the rotors.
brief setup...
t3/t4 60 trim, .60 a/r
lsvtec
b16 head
itr cams
9lb flywheel
stage 2 clutch
aebs intake manifold. i think its ported to 65mm?
3" turbo inlet
2.5" piping with intercooler
3" downpipe (open)
tial wastegate - 7psi
hoping for 250whp tuned crome
Old Oct 19, 2006 | 10:51 PM
Default Re: tb question...58mm vs. 62mm? (the.hamburglar)
ttt
Old Oct 19, 2006 | 11:25 PM
rocket256's Avatar
For $300 that you will spend on a TB. Your not going to see some outrageous gain for the 58mm to the 60mm. But with the 62mm you may see about 7-10hp.
Old Oct 20, 2006 | 06:52 AM
99B16Si's Avatar
i thought the b16a/gsr TB's were 60mm? i could be wrong tho
Old Oct 20, 2006 | 07:33 AM
Default Re: (99B16Si)
if its 7-10 then ill get a type r. it wont cost 300.
Old Oct 20, 2006 | 08:57 AM
Riake's Avatar
Default Re: (the.hamburglar)
Just get a max more to 64mm so you match the TB to your IC piping, really wont make that much of a difference, but it is only $100.
Old Oct 20, 2006 | 09:24 AM
HiProfile's Avatar
Default Re: (Riake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Riake &raquo;</TD></TR><TR><TD CLASS="quote">Just get a max more to 64mm so you match the TB to your IC piping, really wont make that much of a difference, but it is only $100.</TD></TR></TABLE>
Not only that, but I've seen him post that he will modify the gsr TB to work for $20 or so. its maxbore.com
Old Oct 20, 2006 | 10:31 AM
Default Re: (HiProfile)
ya but i kinda want a 62 mm one. ill check out that page. thanks
kulo
Dec 11, 2012 05:24 PM
laocivic
Feb 27, 2008 07:07 AM
GOLDBERG
Feb 27, 2004 01:24 PM
Blown90hatcH
Aug 30, 2002 12:22 AM
