Throttle Body sizing vs IC piping sizing....
Old Aug 27, 2002 | 09:07 PM
Blown90hatcH's Avatar
Default Throttle Body sizing vs IC piping sizing....
Ok, I need to decide on the throttle body vs IC piping. Now the IC piping going into the TB would be 2.5" or approximately 63.5mm. Now that isnt that large. Should I up the IC piping from turbo to TB to 2.75 and run a 70mm TB? Or just keep the 2.5" IC piping and go with a 64mm TB? Here is the setup:
60-1 T4 turbo
SFP race manifold
Built engine
JG Intake mani
SpeedPro
Looking for around 450-500 whp on street driven.
Thanks for the input.
Old Aug 27, 2002 | 10:26 PM
paulzy's Avatar
Default Re: Throttle Body sizing vs IC piping sizing.... (Blown90hatcH)
I think you should stay with 2.5" piping and upgrade to a 65 or 70mm TB
Old Aug 27, 2002 | 10:27 PM
Default Re: Throttle Body sizing vs IC piping sizing.... (paul_vang)
Paul what benefits would I gain from a 2.5" piping and then a 70mm Tb?
Old Aug 27, 2002 | 11:00 PM
paulzy's Avatar
kinda like a venturi effect I guess...I can't really explain it, but I think 2.75" is way over kill in a honda with less than 700 horses.
Old Aug 28, 2002 | 09:29 AM
Hmm....need more info from people. Thanks paul.
Old Aug 28, 2002 | 09:54 AM
93LSivic's Avatar
If im not mistaken you might wanna check out the Corky Bell book. I dont own one but........ I remember someone posting that there is a specific formula in there that tells you what size ic piping should be used in X turbo setup.
Or you can search, but I dont know if you will uncover that thread......definetly archived.
Old Aug 28, 2002 | 12:18 PM
Default Re: Throttle Body sizing vs IC piping sizing.... (93LSivic)
Cool thanks.
Old Aug 29, 2002 | 10:13 PM
Anyone else?
Old Aug 29, 2002 | 10:34 PM
ninesecrx's Avatar
You can make 500 easy whp with 2.25 and 700 with 2.5. Are you palnning on making over 700? The volum might be more with larger piping but the volicty goes way down. Stick to the 2.5
Old Aug 29, 2002 | 10:47 PM
Default Re: Throttle Body sizing vs IC piping sizing.... (ninesecrx)
No just looking for around 500. What size TB should I get with the 2.5" IC piping?
Old Aug 29, 2002 | 10:54 PM
ninesecrx's Avatar
the 64 you have would work...maybe the 65mm Edlebrock? STR has tb's now in I think 64,66,68 and 70mm.
Old Aug 29, 2002 | 11:09 PM
Cool thanks man.
Old Aug 29, 2002 | 11:24 PM
bigTom's Avatar
iv seen 3" ic piping and 75mm tb's make over 600hp and at the same time u take someone like jojo callos and he is using small piping (i think something like 2.25 or 2.5" piping) and im not sure how much power he is makeing but im sure its enough to get his car into the 8's
to sum it up... both work... its up to u imo
Old Aug 30, 2002 | 12:22 AM
ninesecrx's Avatar
Default Re: Throttle Body sizing vs IC piping sizing.... (ek9t)
Jojo uses 2.5 inch piping on his car. He took his exact setup from the white hatch and put it into the integra with the better suspension of the integra and ran 8's with that. He makes about 650hp with his car.
edsperformance
Mar 17, 2012 05:10 PM
80884
Feb 2, 2006 06:01 PM
jdmfun99
Dec 6, 2004 02:36 PM
dmecarboy
Aug 8, 2003 05:55 AM
pub
Mar 23, 2003 12:10 PM
