my compression test results (man its ugly)
Old May 4, 2002 | 06:42 PM
lazyguy's Avatar
Default my compression test results (man its ugly)
gsr motor
170,160,122,153
this is so bad, how can i tell where the loss is coming from, i.e. if its bent valves, head gasket or rings
Old May 4, 2002 | 06:47 PM
sgT's Avatar
sgT
Default Re: my compression test results (b18cURmama)
do a leakdown test that will tell u if its bad valves
Old May 4, 2002 | 07:16 PM
Racebrewer's Avatar
Default Re: my compression test results (sgT)
Well you could try the old way of putting a teaspoon of oil into the cylinder and running the test again. If the compression comes up, the rings would be suspect.
When you did the compression test, was the motor fairly warm and did you hold the throttle open?
Those will change the readings.
John
Old May 4, 2002 | 07:27 PM
hybrider's Avatar
Default Re: my compression test results (Racebrewer)
considering 180-215 or so with no more than a 5-10 loss in between is normal !
then,OUCH !
Old May 4, 2002 | 07:55 PM
sgT's Avatar
sgT
adding oil will make ANY readings higher doesnt matter if the motor is good or bad.
Old May 4, 2002 | 08:15 PM
spoon_ek9's Avatar
Default Re: my compression test results (hybrider93)
whats the stock compression of type r? 200?
Old May 4, 2002 | 09:14 PM
comptechgsr's Avatar
Default Re: my compression test results (spoon_ek9)
what shud ur gsr be @?
Old May 4, 2002 | 11:15 PM
lazyguy's Avatar
Default Re: my compression test results (comptechgsr)
stock gsr compression i thought is 240psi
Old May 4, 2002 | 11:16 PM
lazyguy's Avatar
how do i perform a leakdown test??
Old May 5, 2002 | 05:56 AM
Racebrewer's Avatar
To do a Leakdown Test you need a Leak Down tester (about $80-Longacre has a nice one) and a source of compressed air. The concept is to pressurize each cylinder at top dead center with the compressed air (usually 100 psi) and the leakdown tester will give you the 'rate' at which the compressed air is leaking out of the cylinder.
Then by listening at exhaust tip, intake, crankcase and by checking for bubbles in the cooling system you can make an educated guess as to where the leakage is occurring.
SGT- my experience has been that putting a little oil in a cylinder with a low compression test reading, and re-testing should help differentiate between bad rings vs. bad valves. If the reading comes up substantially it would point to rings, if it only comes up a little its the valves. If nothing changes its a hole in the piston<LOL>.
Yup, not much help beyond that.
John
Old May 5, 2002 | 06:52 AM
lazyguy's Avatar
thanks alot for the info man i gotta do that then
Old May 5, 2002 | 01:36 PM
spoon_ek9's Avatar
does stock gsr compression that high? 240 psi? i think type r is around 200-220?
SilkyJohnson
13
Feb 15, 2011 05:54 PM
humboldt_skim
May 31, 2008 08:18 AM
climb_on
Jul 29, 2007 03:40 PM
Got_soy
28
Aug 8, 2005 12:49 PM
gsr~hatch
Apr 17, 2003 03:19 PM
