Aftermarket camgears whirring. Bad?
Old Oct 19, 2006 | 03:15 PM
SETI20's Avatar
Default Aftermarket camgears whirring. Bad?
So, recently I installed a set of Hayame camgears.
All good and well...they're still sitting at 0deg adjustment.
At the same time I cut out the side of my valve cover. So I can adjust them. And ofcourse look at them.
I have the Invidia G300 on my car, wich is LOUD. But day before I put the silencer back in. Now I noticed a whirring sound.
At first I thought my tranny was going bad. But after closer inspection, it's definately the camgears.
The belt looks fine. They don't seem to rub on anything. No burning smell or unusual heat. No wobble. Just that whirring noise. Sounds like a frickin supercharger.
Is this caused by the aftermarket gears? Or do all of them do this, but I just didn't notice until I opened up my valvecover?
What are your thoughts?
Old Oct 19, 2006 | 03:25 PM
Deetz's Avatar
Crazy Honda Guy
Last time i heard that on a customers car, we found out the gears had ever so slightly been rubbing on the inside of the gear and the head itself because they stuck in a bit further. We had to space them out just a couple mm's to fix the problem.
Old Oct 19, 2006 | 03:32 PM
vw eater's Avatar
are those cam gears anygood?i just bought a set thats why i ask.
Old Oct 19, 2006 | 04:33 PM
insomniac791's Avatar
yea if I had to put money on it I would say its rubbing on the inside of the gears somewhere next to the head.
Matt
Old Oct 19, 2006 | 04:40 PM
shortyz21's Avatar
Default Re: (insomniac791)
are you sure it isnt your distro bearing going bad?
also could the camgears could be hitting that stupid timing cover behind it..
Old Oct 19, 2006 | 10:31 PM
SETI20's Avatar
I'll look for more symptoms of rubbing.
I can't think of anything else either. The belt is just a few K old. SO that can't be it.
Old Oct 19, 2006 | 10:49 PM
Cheeech's Avatar
Default Re: (SETI20)
I agree with the previous posts, could be rubbing just alittle from behind the gear(s). On a side note, those are nice cam gears, they go well with the VC.
Old Oct 20, 2006 | 12:24 AM
neofreak's Avatar
Default Re: (CheechJDM)
thats a badass picture
do you have high-res of it i wanna use that as my computer backround
Old Oct 20, 2006 | 12:51 AM
CRX 2.0V-T's Avatar
Default Re: Aftermarket camgears whirring. Bad? (SETI20)
from the picture it looks like ur belt is grinding the camgears. look at it, look like some of ur camgear been eaten by the belt, maybe u tight it too tight?
Old Oct 20, 2006 | 08:18 AM
SETI20's Avatar
Camgears are used. They came a little worn. Like I said. Not a mark on the belt.
If you remove the ".sized" in the image link you'll get a bigger version.
Old Oct 21, 2006 | 09:53 AM
mrtoastyjr's Avatar
how new is your water pump. the bearings in that could make a wiring noise. try using a long screwdriver and place the tip on the pump and put it handle up to you ear and listen.
Old Oct 21, 2006 | 10:18 AM
SETI20's Avatar
Pump is a few thousand miles old.
My ears are fine. It's DEFINATELY coming from the camgears.
Old Oct 21, 2006 | 10:45 AM
91SiZ6's Avatar
I had the same sound on my Z6 with a Skunk2 gear. It was rubbing the plastic on the rear timing cover.
Old Oct 21, 2006 | 11:26 AM
shortyz21's Avatar
Default Re: (91SiZ6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91SiZ6 &raquo;</TD></TR><TR><TD CLASS="quote">I had the same sound on my Z6 with a Skunk2 gear. It was rubbing the plastic on the rear timing cover.</TD></TR></TABLE>
zingggggggggg
Old Oct 21, 2006 | 03:53 PM
EF9Fanatic's Avatar
Default Re: (Deetz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deetz &raquo;</TD></TR><TR><TD CLASS="quote">Last time i heard that on a customers car, we found out the gears had ever so slightly been rubbing on the inside of the gear and the head itself because they stuck in a bit further. We had to space them out just a couple mm's to fix the problem.</TD></TR></TABLE>
How did you go about spacing them out? My TAS adjustable cam gears rubbed too so I had to ditch the plastic cover that sits hard up against the block.
Old Oct 21, 2006 | 06:56 PM
BlueCrxNC's Avatar
I've had whirring noises before; they were all from the belts (timing, alt., p.s.) being overtightened or bad bearings. Not saying your cam gears aren't rubbing, I can't hear your motor from this far
darkwater_ghost
Dec 13, 2008 12:18 PM
teh hatton
Jul 17, 2007 09:45 AM
jmpgraphy
Aug 1, 2006 02:29 PM
JoshuaVTEC
Dec 11, 2005 10:07 AM
cueballsi
27
Dec 2, 2004 07:52 PM
