slow engine start. alternator or battery
Old Oct 18, 2006 | 10:25 AM
jlh22179tx's Avatar
Default slow engine start. alternator or battery
i have a 98 jdm spec type r and every since i got it has a slow engine start. i thought i had a weak battery so i changed it and its still the same. so im guessing its the alternator??? or starter???
it sounds like it trying hard to start then all of a sudden it would come on.
please help
Old Oct 18, 2006 | 10:37 AM
mugenracer's Avatar
Incorrect heat range or old/worn spark plugs would also make it hard to start.
Old Oct 18, 2006 | 11:14 AM
walker111's Avatar
Default Re: (mugenracer)
Or starter.
Old Oct 18, 2006 | 01:24 PM
migs's Avatar
Default Re: slow engine start. alternator or battery (jlh22179tx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlh22179tx &raquo;</TD></TR><TR><TD CLASS="quote">i have a 98 jdm spec type r and every since i got it has a slow engine start. i thought i had a weak battery so i changed it and its still the same. so im guessing its the alternator??? or starter???
please help</TD></TR></TABLE>
If you have a fresh battery and kept on trying to start it and start it. There is a SMALL possibility the battery could be dead. But the likelihood is small. The alternators job is simply to charge the battery. If the battery is fresh and the turnover is slow, its not the alternator. Push start the car in 2nd gear to rule out the alternator.
Check other areas like the suggestions above. It may be the starter.
Old Oct 18, 2006 | 03:09 PM
2KBLKTYPER's Avatar
Slow engine START?
START is the keyword! My bet is the starter or whatever else connected to it.. Check all the battery terminals, ground cables & connections to the starter.. Clean all corrosions.. If not, take out the starter & have someone look at it. Your from S.F.? I know a great place by 2200 Jerrold ave #k. I think the phone number is 415 282-4077
Old Oct 18, 2006 | 03:28 PM
BMaDOHC's Avatar
Default Re: slow engine start. alternator or battery (2KBLKTYPER)
easy way to check alternator is disconnect battery positive side while running, if it dies then it needs a alternator, if runs then it is good.
Old Oct 18, 2006 | 03:51 PM
2KBLKTYPER's Avatar
Default Re: slow engine start. alternator or battery (BMaDOHC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BMaDOHC &raquo;</TD></TR><TR><TD CLASS="quote">easy way to check alternator is disconnect battery positive side while running, if it dies then it needs a alternator, if runs then it is good.</TD></TR></TABLE>
Thats a big NO, NO!
Who told you that? A guy that drives a 1970 Pontiac?
Modified by 2KBLKTYPER at 5:02 PM 10/18/2006
Old Oct 18, 2006 | 07:01 PM
S-=N=-A-=K=-E's Avatar
Same thing happend to me, i have not had my car running for a while and kept it in my garage for two weeks with the alarm on. i try to start it and it would turn over slowley then give up and would just start clicking. I would say it's the battery. If you do want your alarm on all the time while your car is in the garage at least turn the car over once every day or two for a minute or so to keep the charge on the battery.
Old Oct 19, 2006 | 06:44 AM
walker111's Avatar
Default Re: slow engine start. alternator or battery (S-=N=-A-=K=-E)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S-=N=-A-=K=-E &raquo;</TD></TR><TR><TD CLASS="quote">Same thing happend to me, i have not had my car running for a while and kept it in my garage for two weeks with the alarm on. i try to start it and it would turn over slowley then give up and would just start clicking. I would say it's the battery. If you do want your alarm on all the time while your car is in the garage at least turn the car over once every day or two for a minute or so to keep the charge on the battery.</TD></TR></TABLE>
Your problem is the battery. I dont think its his though.
Old Oct 19, 2006 | 07:18 AM
totsie7944's Avatar
Default Re: slow engine start. alternator or battery (walker111)
sounds like its the starter....
Old Oct 19, 2006 | 07:51 AM
HSPxNick's Avatar
he did say he changed the battery, I don't think is the battery if he changed it. when's the last time you you changed spark plugs? check starter (my friend had the same problem on his lexus, it jus clicks and start after a few tries) but it should be similar on these type of technical problem)
Old Oct 20, 2006 | 11:07 PM
jlh22179tx's Avatar
Default Re: slow engine start. alternator or battery (erasa510)
im planning on changing the spark plugs... i dont know how long this car hasnt been turned on or used before i got the swap.
ryans97ek
12
Mar 10, 2009 09:37 AM
jorge59la
Sep 27, 2007 07:24 PM
LSEGHATCH
20
Feb 5, 2005 07:06 PM
Z_Malloc
Oct 18, 2004 07:05 AM
