h22 swap help
Old Oct 17, 2006 | 05:25 PM
ken2830's Avatar
Default h22 swap help
wats good. I have an h22 in my eg coupe and the problem I'm having is that my motor won't rev pass 4000 rpm. previously I had a broken tps and it wouldn't rev pass 3000 rpm. I installed one from another throttle body and now it won't go pass 4000 so it made a little difference. I did the timing myself when I installed a new belt but I believe I don't have it perfectly. would bad timing cause that problem? and also I don't have an o2 sensor hooked up neither...any help would be appreciated. the ecu is chipped for the h22 ALSO. P.S. IS IT POSSIBLE TO DRIVE THE CAR WITH THAT PROBLEM TO TAKE IT TO A MECHANIC IF I JUST DRIVE UNDER 3000 RPM.. THANKS
Old Oct 17, 2006 | 07:46 PM
Braco11's Avatar
Default Re: h22 swap help (ken2830)
when u installed the new tps, did u re-calibrate it?
Old Oct 17, 2006 | 07:47 PM
JDMRice's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Braco11 &raquo;</TD></TR><TR><TD CLASS="quote">when u installed the new tps, did u re-calibrate it?</TD></TR></TABLE>
yeah recalibrate it, and plug in your o2
Old Oct 18, 2006 | 07:20 AM
ken2830's Avatar
Default Re: h22 swap help (JDMRice)
nah I haven't re calibrated it I don't know how to do that what I was thinking was just to unloosen the tps and just slightly move it to see if it makes a difference..
Old Oct 18, 2006 | 10:06 AM
hondaZvic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMRice &raquo;</TD></TR><TR><TD CLASS="quote">yeah recalibrate it, and plug in your o2</TD></TR></TABLE>
yeah... and i wouldnt drive the car to muh if u think the timing is really messed up... u might wanna have someone check it for u, if ur not sure about it.
Old Oct 19, 2006 | 04:51 PM
ken2830's Avatar
Default Re: h22 swap help (hondaZvic)
come to find out fellas it was the ecu. the ecu was chipped for an h22 turbo setup. so I put my regular p28 and it revs fine now. thanks for the help
Old Oct 21, 2006 | 07:39 AM
JasonST's Avatar
Glad to hear u got that fixed. Put that o2 sensor in! Running without it is ganna make u run really rich and foul up ur plugs if u keep running on it. Also just search on how to calibrate the tps, I've done it multiple times now, cause mine never stays where it should, it's very simple to get the hang of though.
swpdb16
Apr 23, 2010 10:54 PM
laberone
Oct 25, 2006 05:05 PM
h22zexhatch
10
Jun 3, 2005 01:14 PM
EkH22
Jun 5, 2003 06:27 PM
